Author Topic: disable EV sb122 internal crossover  (Read 15075 times)
Sean Bugg
« on: December 30, 2010, 03:14:47 pm »
Just like the title, I would like to by-pass/disable the hi-pass crossover in order to chain two sb122s together.
I feel that the crossover point is too high anyway. 160hz I think.
I would like to run one side of the amp to them and the other to the tops.
Thanks in advance for the help.
Mike Pyle
Re: disable EV sb122 internal crossover
« Reply #1 on: December 30, 2010, 04:02:40 pm »
Sean Bugg wrote on Thu, 30 December 2010 12:14
There is no crossover, just a lowpass filter. The two NL4 connectors are paralelled.
Mike Pyle
Audiopyle Sound
707-315-6204
Dealer: Yorkville, EV, QSC, RCF, KV2, FBT, EAW, Danley, SLS, Turbosound, dBTech
 APB,A&H,Audix,Shure,Powersoft,RoadReady,K&M,Ultimate ,Global Truss,DENON,Chauvet,Elation...
Sean Bugg
« Reply #2 on: December 30, 2010, 04:11:35 pm »
Thanks Mike.
I am confused however. On the back plate it is labeled in and out. In the manual it says you can connect from the power amp to the sub (sb122 a sub that's funny) then to the tops because it will pass only above 140hz or 160hz.
Bob Henley
« Reply #3 on: December 30, 2010, 07:04:11 pm »
Sean Bugg wrote on Thu, 30 December 2010 15:11
Thanks Mike.
Ah, now I see what you're asking.
The NL4s are just in parallel: they pass the full range signal to the tops- there's no low highpass/lowcut when passing a signal through the Sb122.
While the Sb122 isn't the best sub, I like mine - they add a decent amount of low end to my Zx1s, I can carry one in each hand, and they're pretty cheap.
Silas Pradetto
« Reply #4 on: December 30, 2010, 07:10:27 pm »
No one actually answered your question. Take out the input panel, remove whatever circuitry is there (probably just a coil to lowpass the woofer) and wire the speakons direct to the woofer. Should take you two minutes per.
Sean Bugg
« Reply #5 on: December 30, 2010, 07:48:19 pm »
Bob  Healey wrote on Thu, 30 December 2010 18:04
This is what confuses me.
http://www.electrovoice.com/sitefiles/downloads/SB122_EDS.pd f
« Reply #6 on: December 30, 2010, 07:57:20 pm »
Sean Bugg wrote on Thu, 30 December 2010 19:48
What are you finding confusing? The NL4 connectors are in parallel and pass the full range signal. The sub as a built in low pass filter. Very simple.
Sean Bugg
« Reply #7 on: December 30, 2010, 08:10:10 pm »
Mac Kerr wrote on Thu, 30 December 2010 18:57
This is from the link.
An integral low-pass filter allows the SB122 to be directly
connected in parallel with a full-range speaker for truly
impressive low-end output without the need for an
additional amplifier and processor. The filter is transparent
below 160Hz, allowing the SB122 to be used as an
independent subwoofer in biamp applications without the
need to disable the internal filter. For maximum output in
biamp applications and protection of the full-range system
when running in parallel, a 40Hz Hi-pass (subsonic) filter
is recommended
« Reply #8 on: December 30, 2010, 08:18:22 pm »
Sean Bugg wrote on Thu, 30 December 2010 20:10
is recommended
As Mac said-what is confusing about that?
Maybe if you would point out what you find confusing-instead of us trying to read your mind-it might be a little be easier.
dB Audio & Video Inc.
Gareth Marsh
« Reply #9 on: December 30, 2010, 08:18:27 pm »
Sean Bugg wrote on Fri, 31 December 2010 13:48
What that manual is describing is the 2 x NL4 connectors are literally connected directly (in parallel) to each other - the low pass is only after both the NL4 connections - effecting the driver in that sub box only.
The signal can go into either NL4 and out of the other (regardless of how they are labelled) and it will still be the full range signal that the amp is outputting along all the cable runs.
The reason they have done this is so that you can just run one signal out to both sub and mid-high cabinet. The low pass is just to stop the sub getting fed high frequencies, similar to the circuitry for woofers in most passive mid-high boxes.
For your application of linking 2 subs off of one amp channel, just run the NL4 from the amp into one and use another NL4 cable to link into the other. The low pass will only happen once for each sub, the signal between the subs will be full range.
If the 160Hz low pass is indeed to high for your application then you will need to look at using a DSP to filter the signal before the amplifier.
Hope this helps
Gareth
Page created in 0.025 seconds with 16 queries.
