Author Topic: Wiring help on ART MyMonitor - adapter for dual mono vs. only left?  (Read 7793 times)
Ned Ward
Figured we would try out in-ear monitoring with our singer, but rather than jump in and spend a lot of money, we wanted to do this in steps.
She doesn't move around alot, so hardwired in-ears is fine. We use wired SM58 for her which suits her voice fine.
Hardware is ART MyMonitor ( http://www.artproaudio.com/products.asp?type=90&cat=13&a mp;id=67)
The unit passes the vocal mic thru to the mixer, and also has an aux input for monitor. Goal would be to have a monitor mix sent to this from my 01v and give her control over her vocal for a "more me" solution.
Challenge - the Monitor Input on the MyMonitor is looking for a stereo headphone type feed; with a mono 1/4" or an XLR-TRS adapter, it only plays in mono on the right side.
Is there a simple adapter/wiring change that would let me take a mono XLR send from the 01v and with a creative adapter, present a dual mono signal to the MyMonitor aux input?
Pic with wiring diagram attached. I'm not soldering/electronics knowledgeable, but our drummer is an electronics engineer and could also open the pup up and tweak if needed. I've already sent an email to ART but figured the fine minds on this board may have a usable workaround.
Thanks.
index.php/fa/34334/0/
Rob Timmerman
Re: Wiring help on ART MyMonitor - adapter for dual mono vs. only left?
« Reply #1 on: December 20, 2010, 06:42:29 pm »
TS jack to TRS plug wired:
S -> ST -> TT -> R
Basically, build a splitter cable.  Don't forget to label it.
John Chiara
« Reply #2 on: December 20, 2010, 09:40:27 pm »
It should have a mono button...stupid...
"mix is a verb, not a noun" Sooo, as Aunt Bea would say.."Get to it!!!"
John A. Chiara aka. Blind Johnny
Albany Audio Associates Inc.
Troy, NY
518-961-0069 - cell
Ned Ward
« Reply #3 on: December 20, 2010, 10:41:47 pm »
It should but for $70 it doesn't.
There's only 1 power switch and two volume knobs. No mono button.
brian maddox
« Reply #4 on: December 21, 2010, 12:36:56 am »
there are several easy ways to make an adaptor for this.
if you have a F-xlr to M-trs, you can modify it inside either connector to accomplish your goal.
in the xlr connector, move pin 3 wire to combine with wire on pin 2 [technically you should then jump pin 3 to pin 1, but it'll probably work fine if you don't].
or
in the trs, disconnect ring and jump ring to tip.
you could also open the box and accomplish the same thing by moving the wire from the 'ring' connection to the 'tip' connection.
all of these make your connection unbalanced, but that is probably not a big deal for your purposes...
if you've got access to a 'electrical engineer' drummer, these mods should be a piece of cake.  10 minutes and a soldering iron.
and yeah, it should have a mono switch...  Smile
brian maddox
'cheap gear personalizer'
brianm@fcfchurch.com
_____________________________________
brian maddox
www.fcfchurch.com
'do not trifle with the affairs of dragons....
       ....  for you are crunchy, and taste good with ketchup'
Ned Ward
« Reply #5 on: December 21, 2010, 12:31:02 pm »
thanks Brian - have a few F XLR - TRS shorty cables coming from Audiopile and will watch how our drummer mods them. If this works, he's next for in ears. Of course knowing him, he may decide to open up the box and build a better one, with a Mono switch (or better yet, a F XLR jack that does the same thing) for himself.
David Buckley
« Reply #6 on: December 26, 2010, 05:37:41 pm »
Two issues you may face.
The first is that you are mixing a signal direct from the vocalist's microphone, and a return from a digital desk.  The issue here is that the desk return will be out of time with the live mic feed, dues to the processing latency through the digital chain.  So if you have the vocalists mike present in the feed from the desk, you may get a comb filtering thing going on.  So rather than "more me", don't have any of "me" in the feed from the desk, to avoid the problem, hopefully altogether, though depending on stage volume, there may be other stuff picked up by the vocalists mic.
The second is that you're running unbalanced from the desk to the MyMonitor; this may work perfectly fine, if your setup is such that unbalanced line feeds survive intact and uninterfered with down the multi.  If hums and buzzes are an issue, then a balanced to unbalanced transformer (like a DI box but in reverse) should solve the problem.
Tim A Perry
« Reply #7 on: December 26, 2010, 07:37:05 pm »
An adapter cable on the headphone output jack should be cheap and easy.
You don't necessarily even have to solder anything.
Simply obtain a stereo headphone extender cable and cut it in half.
strip back the ends and wire the two hots to the female end together. Then twist the single hot from the male end to the the other two.
Leave the unneeded wire from the male end loose and hook the 2 commons (usually black) together.
Then solder,or tape, or crimp and plug the headphones into it then into the box.
"Music washes away from the soul the dust of everyday life" ~ Berthold Auerbach
Ned Ward
« Reply #8 on: December 31, 2010, 12:35:32 am »
David Buckley wrote on Sun, 26 December 2010 14:37
David - thanks for the reply. Goal would be actually to just give her a mix on the "monitor channel" that includes her vocal and bypass the mic thru to avoid any delay issues as you say. Other change would be having our electrical engineer drummer change the mic input to a line-level input to accept a XLR male, which would make everything much easier.
worst case on the noise, I've got an ebtech hum eliminator (1:1 isolation transformer) that should work.
Having just gotten sensaphonic molds for my Shure buds and spend a day mixing with them, I can definitely see the benefits of IEM - much lower SPL, as well as the drawbacks - you need an ambient mic or you hear nothing.
Still definitely an experiment, and one we'll prove out in practice in our rehearsal studio before taking out live. Over the break i did get a headphone extender cable and female XLR - TRS adapter cables. by tweaking a few of those to sum into mono, this could be an intro into full IEMs. Next purchase would be a rack mount headphone amp. But again, we're walking before running.
Jonathan Kok
« Reply #9 on: December 31, 2010, 01:30:28 am »
Rolls makes the same thing...for about $50.  WITH a mono/stereo switch.  In fact, run in mono, theirs allows for remote powering of the device, via the un-used ring portion of the TRS monitor input, and the PS16.  Which, incidentally, also serves as an un-balancer (XLR input on the PS16).
Jus' sayin' Wink
Page created in 0.031 seconds with 19 queries.
