Art Welter wrote on Tue, 30 November 2010 21:08 |
Stipe,
Nifty design, but it looks to roll off almost an octave above the Tuba 60 if this sim is accurate...
Yes you are right by looking at simulations seems like this...
CB-18 is designed to be "universal" bass solution (not dedicated SUB-woofer). So it can cover relatively wide freq. range even when used alone with upper cutoff freq. high enough so there is no need for dedicated kick bins.
Also idea was to improve sound quality at upper cutoff (seems that goal is accomplished successfully)
and improve cone movement stability (at extreme power) by symmetrical cone loading.
While trying to achieve this in pretty compact size extra deep LF extension is sacrificed.
By give-up from these two goals it is possible to fit longer horn path within cabinet of same size.. but than my goals are compromised.
General idea based on same lines defined as in this article by Jeff Berryman:
http://www.prosoundweb.com/article/building_a_big_woofer_enc losure/LINK
..However builders of CB-18 have reported great SPL flat from 40Hz -up .. with a bit of EQing even from 35Hz achievable (if needed
) - of course HPF @ 30Hz have to be used to protect speaker unit from over excursion damage at high power.
CBe-18 , and especially CBX-18 (I hope once it is built
) will give bit more LF extension (at cost of a bit larger cabinet size)
CB-18 is 374,5 ltr.
CBe-18 = 455 ltr.
CBX-18 = 464,5 ltr.
all dimensioned with "truckpack friendly" on mind
TUBA60 (dual 12 version) =884 ltr. in very weird dimension/size (huge depth dimension)
Also important to notice for honest comparison ..spl plot for dual 12" Tuba60 (on Bill site) is done as 2,83V on 4ohm load which is 2W/1m plot not 1W/1m. According to this even smallest CB-18 is same or more efficient from 40Hz - upwards.
OK, I must admit under 40Hz TUBA60 is still dominant.
Best wishes,
Stipe
