Author Topic: install lighting pipe/bar systems  (Read 17510 times)
Adam Kane
Re: install lighting pipe/bar systems
« Reply #10 on: September 29, 2010, 12:46:47 pm »
Charlie Zureki wrote on Wed, 29 September 2010 09:04
 I think you're missing the point...it's not always about the equipment...it's about HOW it's attached to the building.... and NO ONE can phone that in.....they have to actually be there....ON SITE.
 Hammer
Exactly. I've seen some pretty crappy work with steel cable, forged eyebolts, unistrut, shackles, and grade-80 chain...all of which are perfectly fine to use when implemented within the scope of their intented purpose and load ratings.
Even if you purchase some sort of pre-fab and pre-approved piece of lighting "piping system" (ETC or similar) it still needs to be fastened to the structure correctly or it doesn't matter what stickers are on it.
Chuck Fudge
« Reply #11 on: October 08, 2010, 10:42:37 pm »
forged..not welded...you're right.  anyway....its all got to be rated.  Thats why I hire out, no room for mistakes.
Chuck Fudge
Technical Director
Braden Auditorium/Bone Student Center
Charlie Zureki
« Reply #12 on: October 09, 2010, 12:21:58 pm »
Chuck Fudge wrote on Fri, 08 October 2010 21:42
 Hello Chuck et al..,
 Yes, if there's no rating spec available for a piece of hardware, then, definitely do NOT use the hardware.
 But, the idea or term "rated" can be misconstrued or ignored too.
Even the wire rope and fittings sold at the local "H-Depot" or "Loads" has a "rating". Usually right on the spool or package.
Remember, it's not always whether something is "rated", but, whether it is used with a proper safety margin.
 Cheers,
 Hammer
Be prepared, you'll need it!
Chuck Fudge
« Reply #13 on: October 19, 2010, 11:55:33 am »
only shop the good stuff...I do hang bird feeders at home with the home depot stuff.
Chuck Fudge
Technical Director
Marlow Wilson
« Reply #14 on: November 06, 2010, 06:34:22 pm »
Chuck Fudge wrote on Wed, 29 September 2010 09:43
bmi supply
Very handy link.... I've been browsing their catalogue for 5 minutes and already found a whole bunch of stuff I've been looking for.
Thanks!
I should probably be doing something else right now....
Matthew Haber
    • http://www.matthewhaber.com
« Reply #15 on: November 14, 2010, 12:37:08 am »
I think this thread is probably a good example of, "If you have to ask, it is time to hire a theatre rigger." This sort of job is pretty par-for-the-course and any decent rigger who has done installs should easily be able to handle it. I'm sure someone can point the OP towards a reputable local theatre rigger.
Tim Padrick
« Reply #16 on: November 27, 2010, 02:17:00 am »
If I'm not mistaken, 1.5" schedule 40 has an OD of 2", so you guys are likely talking about the same pipe.
drewgandy
    • http://gandymethod.com
« Reply #17 on: November 28, 2010, 05:00:54 pm »
Tim Padrick wrote on Sat, 27 November 2010 01:17
I think "theater pipe" is supposed to be 1.9" OD.  2" would be the rounded up version.  ?
drew
Page created in 0.042 seconds with 20 queries.
