Author Topic: install lighting pipe/bar systems  (Read 18529 times)
Michael Hoddy
« on: September 28, 2010, 09:09:01 pm »
Does anyone have a source for flyable, permanent install-type stage lighting bar or pipe systems? I have a church install where I need to provide and fly 3 lighting pipe locations for Source Four ellipsoidals with something designed for the purpose that I can mount to proper equipment supports on the structure. I'm not looking for truss. I've seen these before, I just don't know who makes them.
I don't need dimming on them, just a pipe/bar system with mounting points. Each location needs to be around 8 feet in length. Any ideas? Thanks.
Michael Hoddy
Jonathan Kok
Re: install lighting pipe/bar systems
« Reply #1 on: September 28, 2010, 10:47:23 pm »
You sure you want to do this?  Hanging a speaker is one thing--it's the only thing that will ever hang from the points you put in, so making it safe isn't so difficult.  Hanging a pipe from a ceiling opens up the doors for someone at some point in the future hanging something else off it, over which you have absolutely no control.
Duncan McLennan
« Reply #2 on: September 28, 2010, 11:57:33 pm »
What do you mean by 'system'? Do you just mean the pipe itself, or a system like ETC makes with the pipe, and then long box above for circuit distro? Or something else?
dcm
Waterloo & London, Ontario
Michael Hoddy
« Reply #3 on: September 29, 2010, 08:50:47 am »
I'm familiar with the ETC product, but I'm looking for something that's just a lighting pipe or bar with fly-rated structural attachment points- no integrated dimming or circuiting. Pretty simple really. I'm kind of surprised that something obvious hasn't popped up because I've seen this sort of thing in a bunch of church installs by others.
I've seen people and companies build their own with Schedule 40 pipe and assorted hangers, and while I know that Schedule 40 (or 80) pipe is kind of a standard in smaller theaters for this, I am not interested in reinventing the wheel by fabricating something and trying to get a structural engineer to approve it. I'd rather submit a drawing of a pre-existing product that's designed for this.
Michael Hoddy
Charlie Zureki
« Reply #4 on: September 29, 2010, 08:55:49 am »
Michael Hoddy wrote on Tue, 28 September 2010 20:09
  Hello Michael,
  Hanging a pipe for a few lighting fixtures could be a simple job, or a very time consuming project depending on the heighth and design of the building.
  Many people would use a piece of 2" black pipe. (found at any plumbing or hardware warehouse) Now...how they'd hang it is a bit more complicated based on the structure of the building and the availability to mount it securely.
  Hanging the pipe (properly) from rated wire rope and fittings, or from a some metal brackets is a common method.
  But, again, the pipe's hanging apparatus needs to be mounted securely to a structural beam or batten.
  Find a theatrical rigger with experience.
  Good Luck,
  Hammer
  We've seen a lot of hack hangs jobs, and one of the biggest mistakes is some fool screwing a pipe flange into a wood stud (or just the ceiling/wall)
 DO IT RIGHT....Don't be a Dino!
Be prepared, you'll need it!
Michael Hoddy
« Reply #5 on: September 29, 2010, 08:58:18 am »
{QUOTE} We've seen a lot of hack hangs jobs, and one of the biggest mistakes is some fool screwing a pipe flange into a wood stud (or just the ceiling/wall)
DO IT RIGHT....Don't be a Dino! [/QUOTE]
This is precisely what I don't want to do. I figure the plumbing store is a bad place for anyone to build rigging systems from.
If there isn't a pre-fab product, I may just have to sub it out to a theatrical rigger who can certify whatever they build. Is there a lighting rigging design-build equivalent to Polar Focus (whom I love)?
Michael Hoddy
Charlie Zureki
« Reply #6 on: September 29, 2010, 08:58:54 am »
Michael Hoddy wrote on Wed, 29 September 2010 07:50
  Michael,
  it's usually not the pipe that's the problem...it's the METHOD of the hang and the PROPER use of RATED hardware.
 Hammer
Charlie Zureki
« Reply #7 on: September 29, 2010, 09:04:14 am »
Michael Hoddy wrote on Wed, 29 September 2010 07:58
If there isn't a pre-fab product, I may just have to sub it out to a theatrical rigger who can certify whatever they build. Is there a lighting rigging design-build equivalent to Polar Focus (whom I love)?[/quote]
 Hello Michael,
 They'll get the pipe from a plumbing store. The rest of the rigging hardware will be from a supplier that specializes in such equipment.
 I think you're missing the point...it's not always about the equipment...it's about HOW it's attached to the building.... and NO ONE can phone that in.....they have to actually be there....ON SITE.
 Hammer
Chuck Fudge
« Reply #8 on: September 29, 2010, 09:43:36 am »
jr clancy
bmi supply
H and H hardware...etc
The pipe and hanging devices are easy, its how you intend to support the structure.  If steel is exposed, pretty easy situation, but if concrete cealing or wood structure then you are looking at some engineering/structural investigation.
Do you want the pipe to be rigid?  different scenerio.
1.5 schedule 40 black pipe is the standard, 2" is not necessary.  Flat steel brackets that sandwich the pipe provide a mounting point for shackle.  Chain or wire rope from there to structure.  you can also just rap the pipe with chain, and then shackle, and support from that point.  Chain must be welded and rated.
If a rigid system, steel brackets from the ceiling down to pipe.  rated u bolts support pipe to brackets.
Hire a theatrical rigging contractor.  if you are in the midwest, I use Chicago Flyhouse for all our projects.
Chuck
Chuck Fudge
Technical Director
Braden Auditorium/Bone Student Center
Charlie Zureki
« Reply #9 on: September 29, 2010, 12:13:40 pm »
Chuck Fudge wrote on Wed, 29 September 2010 08:43
jr clancy
bmi supply
Chuck
Hello Chuck,
 Some good advice... but,..
 Two inch pipe is also a standard throughout many Theatres in the U.S.  Whether he'd need or want 2" pipe is another story....it does reduce the amount of bend as compared to a 1.5" pipe.
 And, forged chain is better than welded links.
  Hammer
Page created in 0.029 seconds with 20 queries.
