Author Topic: EV EVX-150A Loaded Subs  (Read 8890 times)
Art Welter
« on: May 06, 2010, 08:45:06 pm »
The Welter Systems C-Horns are a very efficient  folded horn. They get loud with as little as 200 watts, but around  800 to 1200 watts  at 8 ohms is a good power level for dynamic music with them. The horn loading raises the impedance above the nominal 8 ohm driver rating. A pair are capable of 133+ dB continuous, 136+ peak output at one meter.
Their frequency and phase response is very smooth, with an easily correctable rising response from 45 to 125Hz.
Very good for rock kick/and bass, but deep enough for dance tracks.
The white trace in the chart below shows one cabinet, brown is two cabinets with the input voltage left the same.
index.php/fa/29975/0/
They use the Electro Voice EVX-150A driver, conservatively rated for 500 watts  sine wave, 1000 watts continuous program power.
It is a very tough (and expensive) carbon fiber speaker.
Cabinet dimensions are 22.5 x 26.5 x 30 inches deep, weight is 105 pounds.
They have a pole mount hole cut for standard 1” EMT pipe.
Price is $600 for the pair plus shipping from Santa Fe, NM 87505.
Art Welter
Art Welter
Re: EV EVX-150A Loaded Subs
« Reply #1 on: June 03, 2010, 12:58:25 pm »
On the graph in the above post, “+0” is equal to 120 dBSPL, using 63 Volts input (500 watts) into a single sub.
For high powered DJ use a 45 Hz 24 dB per octave HP filter is recommended.
Jonathan Heimberg
« Reply #2 on: June 03, 2010, 05:38:48 pm »
PM sent...
Art Welter
« Reply #3 on: June 15, 2010, 08:24:00 pm »
These can ship by Fed Ex, takes less than 4 days most anywhere in the USA.
Art Welter
« Reply #4 on: August 04, 2010, 04:41:33 pm »
Price lowered to $575 for the pair plus shipping from Santa Fe, NM 87505.
Art Welter
« Reply #5 on: October 11, 2010, 07:08:42 pm »
Thumping bottom for bands or DJs.
Cameron Micheal
    • http://www.livesoundforum.com
« Reply #6 on: November 18, 2010, 08:47:45 pm »
PM Sent
Art Welter
EV EVX-150A Horn Loaded Subs
« Reply #7 on: December 09, 2010, 06:56:12 pm »
$570 for the pair plus shipping from Santa Fe, NM 87505.
Jakob Grimm
Re: EV EVX-150A Horn Loaded Subs
« Reply #8 on: December 09, 2010, 09:49:12 pm »
PM sent.
"Touch the board again and you'll pull back a stub."
Art Welter
« Reply #9 on: January 04, 2011, 10:44:11 am »
Art Welter wrote on Thu, 09 December 2010 16:56
Thump.
Page created in 0.047 seconds with 20 queries.
