Timothy Phillips wrote on Wed, 24 March 2010 10:51 |
Hey guys: I was wondering if anyone had any suggestions on how to attach a lavaliere body pack to the top of a persons head. I'm running a theatrical production and we have some mic elements that are a bit bigger then i wanted but i work with what i have lol. I'm stringing up the line so that the mic element lands right on the center of the forehead about 1/2" from their hair line so its not to noticeable yet gives good coverage. I however can't seem to find a good enough way to attach it to their hair or skin to keep it from moving or falling out. Anyone have any suggestions?
... Huh?
First, a mic placed in the manner you describe is more likely to pick up what's in front of the performer than the performer themselves. Second, attaching the BODYPACK to someone's HEAD, unless their costume is nothing but a cowboy hat, would probably be the most noticeable arrangement.
What I think you mean is that you want the mic capsule and cable to be hidden in the performer's hair, and run down the back of their neck to a bodypack under their costume in the small of their back. Though creative, depending on your lavaliere capsules, you'll be more likely to pick up sound from in front of the performer. The capsule will be pointed in a direction somewhere between the actor's feet and their eyeline; most likely, it'll be pointed at monitor speakers, the audience, and other generally undesirable feedback sources.
I would stick to the traditional lav placement, personally. Clip the mic about where the breast pocket of an actor's shirt would be. If hiding the mic is desired, it can be placed on the back side of a suit coat, behind ruffles or neckties, or even under the outer layer of clothing without a significant drop in sound quality (you will have to deal with rubbing sounds as the actors' clothing shifts; surrounding the mic in a small pocket of very smooth cloth like satin can help). If you simply must place the microphone on the performer's head, earworn microphones are the way to go, if there's any way you can make your budget stretch far enough for a few to use on your lead performers. There are models that are virtually invisible from more than a few rows back in the house. As long as a mic isn't a distraction, audiences generally forgive being able to see them on performers as a necessity of modern performing arts.
