Pages: 1 ... 4 5 [6] 7 8   Go Down
Author Topic: Cardioid Sub Array, Subwoofer Steering, HOW TO DO IT?  (Read 78341 times)
Art Welter
Re: Cardioid Sub Array, Subwoofer Steering
« Reply #50 on: April 20, 2010, 03:31:37 pm »
index.php/fa/29633/0/
Bob,
All right, the 66th post here for 6o6 , and now he’s SuperpositionMan  Laughing
Whether called  superposition, wave addition, or mutual coupling,  you are of course correct in that length vs frequency is a continuum, though below 1/4 wave length the continuum does not change much, and above a quarter wave length the changes happen more rapidly.
Not that 1/4 + 1/16th of a wavelength would be a big change, just saying 1/2 wavelength to 1/4 is a bigger change than a 1/4 to 1/8th.
At 16 kHz, where a 1/4 wave length is about the size of the type on the page (+/- 3 dB depending on your eye condition), it is difficult to physically do anything about the differences, we can’t get loudspeakers to dance on the head of a pin.
Down in the <100 Hz range,  wave lengths are long enough that several speakers can be co-located in a near enough configuration to tend to act as a single speaker in the area of interest.  A single EV MTL-4 would be an old example of four 18” drivers with an exit less than 1/4 wavelength in width.
I have not used an FFT analyzer, but using a dB meter or Smaart, I have consistently measured a 6 dB increase doubling cones and power when the sources are within 1/4 wavelength.
That said, large sub arrays are generally well beyond 1/4 wavelength in width, so the “tendency to act as a single speaker” no longer applies.
Art Welter
Tom Danley
Re: Cardioid Sub Array, Subwoofer Steering, OK I was wrong
« Reply #51 on: April 20, 2010, 04:12:52 pm »
Hi Bob, Nick
“So much is made of 1/4 wavelength. But as I see it, it is just a milestone in our brains.”
Well it like this I think, we have some definitions which have a strict meaning, for example, a square wave has harmonics which extend from DC to Microwaves. Or, in acoustics a point source is infinitely small or a line source is infinitely large in one dimension.
In real life on the other hand, there are practical definitions too, for example, on an oscilloscope, it takes a bandwidth about 10 X and 1/10 the fundamental to produce a square wave that looks good perfect to the eye.
A line source gradually stops changing acoustically when it is about 40 wavelengths long and  point sources can combine into a single point source of greater efficiency, if they are less than about ¼ wl apart
Trust me, I didn’t make radiation resistance up and neither did John Eargle or the numerous other acoustic references one can find. Mutual coupling, radiator wave number, radiation resistance curves  etc are real.
“But if somebody wants to give me a procedure that I can use on my FFT analyzer to directly observe "tendencies to act like a single speaker" I will be happy to try them out.”
Procedure?
Sure, I guess so, here are a couple.
Take a number of small identical subwoofers and scatter them around your parking lot.
These are small enough to be omni directional point sources in sub range.
Put your mic somewhere “out there” with a red cone so it won’t get squashed.
Do a narrow band energy vs time measurement with all the subs on.
Now gradually assemble them all in one location, measuring the narrow band ETC each time.
What you will see is they gradually look more like and then combine into one radiation in time.  Once you have all the radiations in less than ¼ wl spacing at the highest frequency in question, there is little further change moving them closer.
If you can do this in a large enough reverberant room with pink noise, you can also monitor the sound power by averaging the spl from a number of far locations, what you will see then is the reverberant sound level will climb from the initial level as the woofers begin to have mutual coupling.
This way you can see the effect of the mutual radiation as it raises the total acoustic power relative to the power of the individual sources up to the frequency where the drivers are too far apart..
If you to try and integrate that subwoofer system with a full range speaker above, you will also find your task becomes vastly easier once the individual subwoofers are all less than a quarter wavelength apart at xover.
I guess those should do.
How this applies is in what Ivan measured, that the close coupled array of four woofers, produced more acoustic power than any of the “array” configurations, even the on axis SPL was less for the directive array, not just the total radiated power.
All that is good when you sell speakers and amplifiers though haha.
When you consider the essentially hemispherical pattern of the close-coupled sources and the power being more or less “area under the graph” it is clear that is so.
There are times when it is desirable to shape the dispersion pattern, the original issue was how best to construct arrays and how do they actually measure.
Best,
Tom Danley
Anthony Risi
« Reply #52 on: April 20, 2010, 05:50:23 pm »
Hello Tom,
I am a little confused about something here.  I have 4 of the TH-115s, and they are absolutely amazing.  I have always either stacked them on either side of the stage ( mainly because my tops need something to sit on) or have center clustered them.  I have always been amazed at the power increase by clustering them all together.  I understand by reading this post how that is happening, so here is my question.  If I got 4 more TH-115s would it be better to put 4 on each side of the stage, or center cluster a block of 8 of them.  I ask because would a block of 8 of them put the drivers further apart then a 1/4 WL at the highest frequency?  I am no expert on this and didn't know if I was understanding what was being said correctly.
Thanks
Anthony
Re: Cardioid Sub Array, Is it just me??
« Reply #53 on: April 20, 2010, 06:02:37 pm »
Tom Danley wrote on Tue, 20 April 2010 16:12
Is is just me or am I the only one who is actually interested in MEASURING something?
I mean it is not that hard-Heck for the point in this discussion you don't even need to do polars-just a simple on axis measurement-a decent distance away from the array-whatever type it is.  The argument is not about what is happening at 180
dB Audio & Video Inc.
Adam Schaible
« Reply #54 on: April 20, 2010, 06:33:17 pm »
Valid point, but from my perspective it's nice to read a lot of the theory, comprehend, etc - so I think it's great.
« Reply #55 on: April 20, 2010, 06:40:38 pm »
Anthony Risi wrote on Tue, 20 April 2010 17:50
Hello Tom,
Thanks
Anthony
As usual-it depends.  There are two things at play here-center cluster vs side stacks.  There are advantages and disadvantages to each method and it depends on the particular situation and what works well in one does not work so well in another.
The best way to stack multiple TH115's is to lay 2 of them on their sides with the exits in the middle, and go as high as you can or have cabinets.  In the case of 8, you would go 4 high-but in a center cluster that would be to high for most stages.
If you just stand them up, then 8 would start to form a sideways "line array" and you would start to pull in the coverage on the sides.  This may or may not be a good thing-depending on what area you are trying to cover.
In most cases I would put 4 per side. 2 over 2.
You can help to reduce the power alley by turning down 1 side a little bit.
Everything regarding loudspeakers and how they are deplyed is a compromise.  It is all about finding the best compromise for a particular situation.
Bob McCarthy
« Reply #56 on: April 20, 2010, 07:53:57 pm »
Shazzam!!!! You mean there's analyzers out there! I always wanted to try one. Laughing
Ivan,
I have an opportunity next week during a seminar I am teaching to set up 4 subs in end-fire and monoblock config. It will be indoors in a small room - but since I am not a manufacturer, rental house or holding any research grants, it is the best I can do. My plan is to compare the forward direction SPL of these array configs to that of a single unit. Working title: "The Search for the Lost dB"
Will keep you posted but it will be some time before it leaves post-production.
6
« Reply #57 on: April 20, 2010, 08:05:32 pm »
Adam Schaible wrote on Tue, 20 April 2010 18:33
And the theory is great-but it is also a very good idea to see how the real world stands up to the theory and vice versa.
« Reply #58 on: April 20, 2010, 08:10:38 pm »
Bob McCarthy wrote on Tue, 20 April 2010 19:53
That is exactly my point.  I first brought up the point of the directional arrays not having the output of the same number of stacked boxes almost 2 years ago.
And to date NOBDOY (that I am aware of) has tried to repeat even the on axis measurements. Rolling Eyes
Surely there are people on here who have access to all the needed gear.
Lots of people have disagreed-but none have even taken a measurement to prove their point.  I am not sure what that is saying. Confused
And remember that my measurements were taken outdoor in a free field.  (OK-a parking lot).  I have not done any indoor measurements to compare the different types-so I have no idea what the results would be.  I would suspect the room will have lots to do with the final outcome.
Bob McCarthy
« Reply #59 on: April 20, 2010, 08:22:25 pm »
Tom Danley wrote:
Understood that you did not make these terms up and no skepticism as to their having demonstrable effects. Hats off to you for working them into a sentence. Laughing
Understood also that as sources get closer together they more closely resemble a single source.  Here is where (I believe) the expression/wording etc. got fuzzy: Way up this thread it was stated that the 4 closely coupled boxes would have the same polar pattern a single speaker- I think it was in your first one of this thread.  This is what I disputed but wait.....
If you meant that it will have the polar of A single speaker. Fine.
If you meant (and this is what I took it to mean) that the combined will have the same pattern as the 4 individual elements that comprise it - that is where I diverge - and everything I have posted on this thread is prediciated on THAT premise.
Combined to create a NEW and UNIQUE quasi-"single" speaker, yes I am with you, regardless of whether it is the result of resistance, radiators or air conditioners. Laughing  the lack of nulls that comes with 1/4 wl spacing makes it look similar to a single speaker.
The combined "speaker" is narrower than the unit component by SOME amount (as previously stated). Kind of looks like we built some horn steering for the speaker, although it is a funny horn - leaks out the back!
So, yes I completely agree that we can fuse the speaker together, but the displacement, however small will reshape it into a new polar - albeit - a polar recognizable as a combined entity.
Cheers
6o6
ps: If there is "mutual coupling" then there must be "non-mutual coupling" eh? Laughing
Pages: 1 ... 4 5 [6] 7 8   Go Up
Page created in 0.067 seconds with 22 queries.
