Lee Douglas wrote on Tue, 14 July 2009 01:10 |
Thanks Ivan and Don for the info. Any published spec's around? Don do you high pass them at 30hz or is that their roll off point?
I kind of expected them to go considerably lower (not that 30hs isn't low) because of the motor design if not for the driver size and enclosure size. Not a huge advantage over a pair of well designed 18's really. Which is probably why they didn't catch on, I guess.
I think I was hoping for special effect low, so I could turn my basement theater into a mini-matterhorn or something. Of course they may be a differet beast all together in a much smaller room.
You should high pass all loudspeakers to protect from overexcursion.
The freq response is not just the driver and enclosure size. There are cabinets that go a lot lower with a lot smaller drivers.
If indeed they are relatively flat to 30Hz, that is quite a bit lower than most 2x18's. The max output and overal freq response and tone character is what makes a loudspeaker successful.
If you are talking about HT applications, then you will get some room gain in a small room. That will help extend the low freq response. But 30Hz (depending on how well they actually do it?
)is not all that low for those applications.
But if they do what you want them to, then go for it.
