Pages: [1] 2 3   Go Down
Author Topic: PICTURES inside an SB1000  (Read 18960 times)
Shane Presley
    • http://www.bssproductions.com
« on: July 09, 2009, 10:52:26 pm »
These are older, when I was considering possibly building some, but decided not to... I know there's plenty of discussion as to open and closed chambers in this guy, so again pictures are best... sorry for the multiple posts, I don't know how to put them all in one message
index.php/fa/23653/0/
Shane Presley
Re: PICTURES inside an SB1000
« Reply #1 on: July 09, 2009, 10:56:51 pm »
from the back speakon plate through to the inside
index.php/fa/23654/0/
Shane Presley
« Reply #2 on: July 09, 2009, 10:57:49 pm »
index.php/fa/23655/0/
Shane Presley
« Reply #3 on: July 09, 2009, 10:58:46 pm »
index.php/fa/23656/0/
Tom Manchester
    • http://www.electrosoundsystems.com
« Reply #4 on: July 17, 2009, 04:05:55 pm »
Neat. I've always wondered what the smaller tube ports in addition to the large center slot port accomplished. Why not one or the other? Anyone know?
-Tom
Electro Sound Systems
drewgandy
    • http://gandymethod.com
« Reply #5 on: July 17, 2009, 09:51:06 pm »
Tom Manchester wrote on Fri, 17 July 2009 15:05
3 thoughts:
1. Some people wouldn't know that it was a "bass reflex" without some round holes.
2. They originally had just the slot but then realized it was tuned too low so they added the holes.
3. The round port is a "test" port for checking that your woofer box is working.  While playing some bass you put your hand in front of the port and if you feel air chugging then it's good.
drew
The Guy
« Reply #6 on: July 20, 2009, 05:10:51 pm »
drewgandy wrote on Fri, 17 July 2009 21:51
3 thoughts:
drew
I think you're onto something here.  The SB1000 original model did not have the supplemental round ports, and the new SB1002 is also lacking these ports.
-J
Tom Manchester
« Reply #7 on: July 20, 2009, 08:39:07 pm »
Perhaps it had to do with the switch from older RCF L18-p300's to the newer 18-sound drivers that they added the ports.
-Tom
drewgandy
« Reply #8 on: July 21, 2009, 01:08:58 am »
Tom Manchester wrote on Mon, 20 July 2009 19:39
Ok, now Shane has to put the drivers back in and measure the resonant frequency then plug the holes and do it again.  My first thought from Tom's post was that the tuning would change pretty dramatically with the additional holes; so much that just a woofer change wouldn't explain it.  But maybe the shift isn't so much.
drew
Jon Waller
« Reply #9 on: July 22, 2009, 10:23:06 am »
Tom Manchester wrote on Fri, 17 July 2009 16:05
Perhaps it has to do with driver cooling.  The round port tubes look like they end right above where the magnets on the drivers would be, and they help heat escape that would build up in the front corners of the box, above the woofers.  This could improve driver reliability and reduce power compression losses.
Engineer
ISP Technologies
Pages: [1] 2 3   Go Up
Page created in 0.022 seconds with 16 queries.
