Pages: 1 [2] 3  All   Go Down
Author Topic: Wireless DMX: 900MHz or 2.4GHz band?  (Read 17209 times)
Bob Charest
    • http://www.bobcharestband.com
Re: Wireless DMX: 900MHz or 2.4GHz band?
« Reply #10 on: January 05, 2009, 09:58:00 AM »
Bob Charest wrote on Mon, 05 January 2009 08:46
George Linkenhoker wrote on Mon, 05 January 2009 08:23
Hi Matt,
I have been using the w-dmx from wireless solution http://wirelessdmx.com/ (snip) You basically synchronize a transmitter with a receiver and they stay together hopping around the spectrum to the cleanest channel.
Hi George,
Thanks for relating your experience with the W-DMX units. Do you know if one can use one transmitter and synchronize it to three receivers, or is there a one-to-one correspondence needed between the units?
Also, I just saw a much lower price posted by SIRS-e on ebay, so now my interest is really piqued, at least for those units. I wonder how they compare in stability to the W-DMX units.
Best regards,
Bob Charest
Hi George, Please scratch the question about multi-point operation, as I just read the PDF available from W-DMX.
Thanks!
Bob Charest
« Reply #11 on: January 05, 2009, 10:14:34 AM »
Matt Dittman wrote on Mon, 05 January 2009 08:55
I know what you mean about the price point.
Some of the offerings by SIRS-e are found on ebay China-direct. They're just marketed by SIRS-e.
I don't know if there would be much difference between the ones that come straight from China and those that are repackaged as a company's product, albeit for a higher price.
Like the Chauvet LED par cans that you can get as unbranded cans, for cheaper.  Same thing without the name.
Hi Matt,
On the SIRS-e site the price for a pair of transceivers is $391, On ebay they're listed as $430.16... I'm very tempted to place an order directly through the company. There appear to be a number of slightly different units listed there, so I've got to check a bit more. I wonder if the W-DMX units have come down in price and I'm just not finding it...
Best regards,
Bob
George Linkenhoker
« Reply #12 on: January 05, 2009, 10:15:20 AM »
No problem.  I think that is actually one of my favorite parts.  One transmitter can do like 1000 receivers or something.  I've seen a few movers and other fixtures coming out with built-in wireless receivers as well as at least one console that has a built in transmitter. Leprecon has a set of dimmers with built in w-dmx now too.
There is a bit of a trick to the w-dmx though.  When you sync up the transmitter to multiple receivers, you have to release all the receivers, then tell the transmitter to sync. If you leave a receiver in sync then try to sync the others, I have had it lose any it was originally with.  If you are doing seperate universes, your best bet is to plug up all the receivers and transmitters for one, sync them, then power those down and power up the second set and sync.  Once paired, I haven't had any of them lose sync. It is rare that I have to re-sync mine usually just plug in and go. Just on larger shows if I sub out/from the other company we work with here.  We own 2 transmitters and 3 receivers, other guys have like 2 transmitters and 6 receivers.
I think the big thing comes to how much you can trust the product as I know I was skeptical at first.  My boss actually picked up the first set for us and I didn't even know when I would use it because I wasn't sure how it would work in my setups. I wouldn't say I use it every setup, but for my larger shows and certain venues we go into I will take a set.
-George
Matt Dittman
    • http://attagurlrex.com
« Reply #13 on: January 05, 2009, 10:23:44 AM »
Bob Charest wrote on Mon, 05 January 2009 10:14
Hi Matt,
Best regards,
Bob
That's true if you look for SIRS-e branded stuff.
Look at the GTA Digital Inc158's 2.4 GHz offering.   Identical specs, and their 900mHz offering is identical... same images, even... as the SIRS-e one.  Same model number - DMXW2.4.
$345 free shipping.
Craig Leerman
« Reply #14 on: January 05, 2009, 11:18:13 PM »
I have been looking at those wireless units on ebay. I want to buy a pair so I can focus a show by myself in a man lift, using the wireless and a Pocket Console.  I'm getting really tired of yelling "Next, Next,  NOOOO the other one, Go back!" etc.
My main concerns are they use either a 9Volt or 12volt power supply, so I can use either a 9V battery, or a 12V camera battery.
Craig
Tim Palmer
    • http://www.putfile.com/palmeris
« Reply #15 on: January 06, 2009, 08:40:04 AM »
For what it's worth I run 4 of the Chauvet 900 Mhz units, 1 transmitter and 3 receivers( 1 on the truss, 1 on each follow spot). I had 1 of the units bad out of the box and sent it in to chauvet, they replaced it. I have never had any problems with interference or erratic behaviour of these devices in the small setups I have done.
Bob Charest
« Reply #16 on: January 06, 2009, 09:45:10 AM »
Tim Palmer wrote on Tue, 06 January 2009 07:40
Hi Tim,
I think I might have had the earlier units prior to Chauvet's D-Fi 2.0. I wish that my experience had been like yours, though. I may try again, but with quite a bit of wireless audio gear in use, my frequency coordinations will be simpler if I use gear that's in the 2.4GHz range. Out of the 4 I had initially bought, 2 were bad out of the box, so between the build quality and the first iteration of the technology I couldn't hang with it.
Best regards,
Bob Charest
Henry Cohen
« Reply #17 on: January 15, 2009, 04:37:07 PM »
Matt Dittman wrote on Sun, 04 January 2009 21:27
My band is trying to cut down on our setup time some more.  I have 7m of triangle truss in the back and a tree up front.  The lights are run via laptop software MIDI'd with a foot controller. It would be nice to put the tree on whichever side we want, and put the computer whereever without running cables everywhere.
The Chauvet and SIRS-e wireless DMX offerings are getting pretty low priced.  Seems like they come in 900MHz and 2.4GHz offerings.
Which is 'better' for a small scale installation? I have heard both sides, that 2.4GHz may be stronger but the 900MHz band isn't as cluttered.
Thoughts?
If this is a permanent install, the simple answer is to determine the existing spectrum usage in the venue as well as any planned or potential future deployments and choose the operating band accordingly.
If on the other hand this a portable application, odds are 900MHz might be the better option, ALL else being equal (i.e. build quality, RF power output, detachable antenna, RX sensitivity, feature set). 900MHz, especially in rural and suburban areas, is generally significantly less congested than 2.4GHz, and RF propagation characteristics are better for this type of application.
However, several factors may make 2.4GHz a better choice: If the venue has a 900MHz enterprise cordless phone system [that connects directly to the PBX/KSU]; there's heavy local Amateur radio activity (they are the primary service in 902-928MHz), one of the lower end 900MHz wireless intercom systems (such as Ear-Tec) is used in the venue; 900MHz wireless mics are used, and the fact that the better wireless DMX systems are 2.4GHz.
Henry Cohen
Production Radio Rentals
"Every new radio emitter since Marconi’s 2nd transmitter has caused interference to other systems!" - Michael Marcus, Oct '07
Thomas Bishop
« Reply #18 on: December 13, 2010, 01:10:30 PM »
Okay... Sounds like SIRS-e is bumping the thread....  I'll bite though, as I've wanted to know for a while.  Bob, did you ever buy the SIRS-e product?  If so, how has it been working out?
Bob Charest
« Reply #19 on: January 03, 2011, 07:15:59 PM »
Hi Thomas,
Sorry for the slow reply - I've been used up with a number of other things, and today is the first day I've looked at the lighting forum in quite a while...
I never bought wireless DMX gear, so I can't comment on any particular brand from personal use. The most expensive gear appears to function the best... no surprise there!
Best regards,
Bob Charest
Pages: 1 [2] 3  All   Go Up
Page created in 0.02 seconds with 20 queries.
