Author Topic: DMX Booster  (Read 950 times)
Corey Ging
DMX Booster
« on: April 18, 2008, 09:26:16 am »
I have searched the forum and found a few old topics, but wanted to get any new ideas.
I am looking for recommendations for a single channel DMX Booster.  I have looked at the Elation splitter/booster but that is more than I need.  Has anyone found or used a single channel DMX Booster?  Any other ideas?
Thanks.
John Birchman, CTS
    • http://www.jrbtechnical.com/
Re: DMX Booster
« Reply #1 on: April 18, 2008, 12:17:43 pm »
Why do you need a booster? Are you going more than 1000' feet?
If you are having problems and it is less than 1000' feet - do you have the data chain terminated?
Why Terminate?
http://www.dfd.com/whyterm.html
Are you using the correct cable type, or using audio cable (which may work in some cases, but is not the correct cable for data/DMX)?  These are the two most common problems with DMX that I have seen, it's pretty robust when used correctly.
If you are going more than 1000' Doug Fleenor Design has a Isolation Amplifier (Model 121) that has a MSRP of $421.30.
http://www.dfd.com/121.html
John
John Birchman, CTS
Freelance AV and Stage Technician
JRB Technical
Lake Buena Vista, FL
Page created in 0.072 seconds with 19 queries.
