Author Topic: Live Sound Newbie FAQ  (Read 34851 times)
Dave Dermont
    • http://www.geocities.com/livesound101/
« on: December 20, 2007, 09:33:56 am »
Here is a list of some of the forum's most frequently asked questions, with links to pertinent discussions.
1. What's your favorite kick drum microphone?
http://srforums.prosoundweb.com/index.php/mv/msg/27721/0/0/8 1/
http://srforums.prosoundweb.com/index.php/mv/msg/24074/0/0/8 1/
2.What are your favorite headphones?
http://srforums.prosoundweb.com/index.php/m/273533/81/?srch= headphones#msg_273533
http://srforums.prosoundweb.com/index.php/m/255423/81/?srch= headphones#msg_255423
Another good way to get information is to use the Forum Search Function
I will leave this sticky and unlocked so people can make suggestions and we can kick around some ideas.
Be advised that the FAQ discussion will eventually be trimmed and locked, leaving only the FAQ.
Thanks
Dave Dermont - Chief Lizard, LAB Lounge
WARNING: Dates In Calendar May Be Closer Than They Appear
Danny Mullins
Help with your first PA system
« Reply #1 on: December 20, 2007, 09:49:51 am »
You need to add..."I am building my first PA, where do I start?"
  http://srforums.prosoundweb.com/index.php/m/234265/16053/?sr ch=Advice+on+First+Sound+system#msg_234265
  http://srforums.prosoundweb.com/index.php/m/272209/16053/?sr ch=Advice+on+First+Sound+system#msg_272209
These are just a couple from a quick search, there are a lot more.
The offer is "A penny for your thoughts", but we always give "Our two cents worth". Is someone making a profit?
Andy Peters
    • http://www.latke.net/
Exciters, Enhancers, and Similar Products
« Reply #2 on: December 28, 2007, 01:18:49 pm »
Another FAQ:
Q: "I'm thinking about getting an Aural Exciter (or similar product). What do you all think?"
A1: "Don't bother. They all suck. Spend the money on another microphone."
A2: "Never use these things across the main outputs. They might be useful as on an individual channel insert. But you're better off spending the money on another microphone."
-a
"This isn't some upside down inverted Socratic method where you throw out your best guess answers and I correct your work." -- JR
SteveKirby
Setting Limiters to Protect Speakers
« Reply #3 on: December 31, 2007, 01:39:55 pm »
Another excellent thread on setting limiters for the power capacity of the speakers, including the math for working it out from both amplifier power or fixed gain amps:
 http://srforums.prosoundweb.com/index.php/m/218674/23615/0// /17922/#msg_218674
This was listed on a thread about bi-amping.  Bunches of newbs have asked about setting limiter thresholds and there is usually a response about either setting to prevent amp clipping (which technique is described in the study hall although largely obviated by built in soft-clipping limiters built into modern amps) or a comment about setting it to protect the speakers, but with no guidance about how to do that.  Thank you Ryan Jenkins for this very clear response.
Ryan Garnett
Gear Guide
« Reply #4 on: January 02, 2008, 02:11:04 pm »
http://srforums.prosoundweb.com/index.php/t/17828/12972/
A guide to what pieces of gear make up a system.
Donnie Evans
Re: Live Sound Newbie FAQ
« Reply #5 on: February 29, 2008, 03:17:26 pm »
This one isn't asked all that frequently, but it's a good thread that I think doesn't need to be lost.
Calculating Limiter Settings
Shump In Da Tub!  www.ogeecheeriverband.com
Too Tall (Curtis H. List)
Re: Exciters, Enhancers, and Similar Products
« Reply #6 on: June 18, 2008, 11:47:18 am »
Andy Peters wrote on Fri, 28 December 2007 13:18
Another FAQ:
-a
+1
They belong in a studio, if anywhere.
A band hired me to mix their set on another person's PA in a night club.
The guy had a nice system in general, but he used some kind of exciter over the mains.
I switched it in and out a few times, then I made a small EQ change on his 1/3-octave EQ and asked if it sounded the same as his exciter.
He said yes, while scratching his head.
Too Tall
        Curtis H. List
             Bridgeport, Mich.
        I.A.T.S.E. Local # 274 (Gold Card)
        Lansing, Mich
Independent Live Sound Engineer (and I'm Tall Too!)
Bennett Prescott
    • http://www.adraudio.com
« Reply #7 on: June 18, 2008, 02:12:43 pm »
Can someone find and link to any of the threads regarding "why subwoofers create a power alley, how cardioid subwoofers work, and why it always sucks when I stack my subwoofers left and right, but sometimes not indoors, or on a tuesday"?
-- Bennett Prescott
ADRaudio d.o.o.
Cell: (518) 488-7190
Tony "T" Tissot
    • http://www.4dbsound.com
Guide to "How Much Power"
« Reply #8 on: June 27, 2008, 11:57:03 pm »
I find this a very simple, and informative discussion about amp sizing questions. - Particularly the link to the Peavey tech. note.
http://srforums.prosoundweb.com/index.php/m/335411/35327/0// /15490/#msg_335411
You'll learn - under-powering is not the culprit for driver damage. Expecting "Champagne" results from a "Beer" budget is.
My favorite quote: "Inexperienced operators often try to use a system that just doesn't have enough power (speakers and amps and AC power) to do the job properly, not the power of the speakers themselves. This results in pushing the system way too hard and making failures more common."
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
John Wilder
    • http://www.wilderamplification.com
« Reply #9 on: October 12, 2009, 02:36:28 am »
How about...
How does the amp get full output power when the "volume" knobs aren't turned up all the way?
The knobs on a power amp are NOT volume knobs. They do not alter the amplifier's power gain in any way.
They are "input attenuators" and they are a matching device. They are used to "pad" the input sensitivity so that the input sensitivity of the amplifier matches the mixer's "max before clipping" output.
Most power amps have an input sensitivity of 1-2Vrms with no input attenuation. However, a typical +4dB mixer can kick out about 8-10 volts before the mixer clips...WAY too much signal for the amp input with the attenuators up all the way. So the input attenuators give you an "adjustable pad", allowing you to match the input sensitivity of your power amp to your mixer's "max signal amplitude before clipping" value, allowing you to get max possible gain from your mics and from the mixer to the amps without the system being so sensitive.
You'll still get full power output...again, the power gain is a fixed value and cannot be altered. It's just gonna take a much bigger signal from the mixer to get that max output, which is a good thing. Benefits - lower noise floor, amps aren't near as sensitive/feedback reduction/elimination, ability to get max possible gain = highest signal/noise ratio.
Now if your amps are not reaching full output power before the mixer clips, you have your attenuators turned down too much. Open them up some. If the amp is hitting clip before the mixer is (i.e. you can still get more gain from the mixer without clipping the mixer itself yet the amp is already clipping), turn the attenuators on the amp down. The trick here is to get the mixer and everything downstream of it to hit its clip point at exactly the same time. This is known as setting a proper "gain structure".
With the speakers disconnected, if you were to inject a pink noise signal into a mixer channel, set the channels EQ flat with low shelving filters off, channel and main faders at "0" (unity gain), then slowly increase the gain/trim of that channel, everything downstream of the mixer including the amps should hit clip at exactly the same time the channel's "Clip" indicator just starts to indicate clipping.
Page created in 0.025 seconds with 15 queries.
