Author Topic: Hole punch for Neutrik 'D' size holes  (Read 18188 times)
Zeb Chamlee
« on: October 27, 2007, 04:33:12 pm »
I have tried searching here and on the web, but cannot find anything about a hole punch/knockout tool made for the Neutrik D standard sized hole.
Does anyone know anything about a place where I could order one (short of having one made)?
GregMorrison
Re: Hole punch for Neutrik 'D' size holes
« Reply #1 on: October 27, 2007, 05:29:51 pm »
I use a Greenlee Slugbuster for a 3/4" knockout..just enough room to slide an NL4 chassis mount in.  I believe the actual hold diameter ends up about 15/16"
John Birchman, CTS
    • http://www.jrbtechnical.com/
« Reply #2 on: October 27, 2007, 11:28:23 pm »
The specification is a 23.80mm (0.9370") diameter hole.
A 15/16" hole is 0.9375" and would be about as close as you could get without getting something custom.
John
John Birchman, CTS
Freelance AV and Stage Technician
JRB Technical
Lake Buena Vista, FL
« Reply #3 on: October 27, 2007, 11:39:26 pm »
John Birchman, CTS wrote on Sat, 27 October 2007 23:28
John
That might be a tight fit. The drawings of the panel cutouts I've seen show them as being 24mm, or .945" for D series or P series. The combo connectors are 23.8mm. A 15/16" punch might be a little snug, although it may be worth a try. A 1" will be pretty loose. The other option is to have someone with a water jet cutter cut the panels.
John Birchman, CTS
« Reply #4 on: October 27, 2007, 11:53:59 pm »
That information is from Neutrik:
index.php/fa/12020/0/
John
John Birchman, CTS
JRB Technical
« Reply #5 on: October 27, 2007, 11:59:05 pm »
So is this:
index.php/fa/12021/0/
Duane Massey
    • http://www.ozknozz.com
« Reply #6 on: October 28, 2007, 01:27:16 am »
I use a uni-bit if I'm mounting in aluminum, but there are draw-thru's that will work in steel;
This looks like a good choice:
http://www.irwin.com/irwin/consumer/jhtml/detail.jhtml?prodI d=IrwinProd100141&search=false
Duane Massey
Houston, Texas, USA
Zeb Chamlee
« Reply #7 on: October 29, 2007, 12:01:08 pm »
Thanks for the replies everyone.  I guess I should have been more specific.  I am looking for a punch that also punches the small screw holes on the sides as well.  For some reason, I thought I had seen one once.  Perhaps I am mistaken.
As for water jet cutting, we usually have all our panels custom made and labeled, but occasionally things change or something unexpected comes up and we need to make a hole on site.  We have a hydraulic punch set with a round punch that works for the large hole.  However, if you have multiple connectors to mount, getting all the small holes perfectly aligned get quite frustrating....
Thanks!
John Birchman, CTS
« Reply #8 on: October 29, 2007, 01:18:19 pm »
I think most people who are making panels more than the odd "one off" are having a CNC machine mill the panels.  There is no all in one "punch" that I have heard of for that particular connector hole set.
John
John Birchman, CTS
JRB Technical
Page created in 0.041 seconds with 19 queries.
