Pages: [1] 2 3  All   Go Down
Author Topic: your thoughts on tuba 36's / bill fitz designs  (Read 14182 times)
josh cohen
    • http://www.weloveshift.com
« on: October 24, 2007, 05:32:33 am »
found a builder in northern louisiana
what are your opinions on the tuba 36 subs?
Josh Cohen
Sense Sound / Shift Industries
New Orleans, La
504.231.2030
Les Webb
Re: your thoughts on tuba 36's / bill fitz designs
« Reply #1 on: October 24, 2007, 10:27:26 am »
josh sense wrote on Wed, 24 October 2007 10:32
i think thier teh best wons eva!!!   Very Happy  Very Happy
I'll get you that quote as soon as I can Josh, sorry for the delay.
Les
Bill Fitzmaurice Authorized Builder
Jeff Babcock
« Reply #2 on: October 24, 2007, 12:59:37 pm »
If your intended use is DJ work then T36 may be an ok choice.  Those are very large horns.  They tend to have a dip in the kick drum range, but go pretty low, and of course perform much better in multiples.  I have not heard the 36 (I have heard other models) but I believe they have been tested at shootouts before.  Performance will not be as good as a Lab sub, but on the other hand it will be much cheaper to build and be significantly lighter in weight.
Les Webb
« Reply #3 on: October 24, 2007, 01:34:00 pm »
Jeff Babcock wrote on Wed, 24 October 2007 17:59
I own/have built a whole herd of 'em.  The one thing they sound absolutely best on is kick drum.  I have not heard a sub sound better on kick and I've heard many dual 18's and horn loaded subs, most of the big name players.  I have not heard Labs however.
Jeff Babcock
« Reply #4 on: October 24, 2007, 02:51:58 pm »
Hi Les,
I'm not saying they will sound bad on kick, just that typical Tuba freq response (at least that I have seen measured NOT on the BFM site) has a dip right at the fundamental freq of many kicks. This is one of the reasons why Mr. Fitzmaurice recommends Titans over Tubas for live music.
I have found the charts on the BFM site to be less peaky than actual measured subs at events.  Look at the T48 for example which Leland brought to the recent sub shootout in Tulsa.  I think Leland was somewhat surprised.  The results were similar to the site but certainly more peaky.  He brought a pair so I wouldn't suspect a faulty build.
In multiples peakiness will smooth out anyway, and I don't doubt at all that you can get a very good sounding kick with T36's.  The top box will be a big factor too.  I have some T48's, and while they are good, I have certainly heard better, abeit considerably more expensive subs.  Of course I have no T36 to compare to.  One big factor is that there are many options when building the T36, so that is an issue in knowing if we can really compare apples to apples.
What variation of the T36 is Josh looking at?  The dual 15" version would be a bass monster, although physically huge.
I presume the T36's value is much like the T48 - a highly efficient sub that gives the end user with a modest budget the ability to get performance comparable to many of the big boys, in some cases better, albeit not the absolute top of the heap. There are minor comprimises in Bill's designs based on using stock Eminence drivers, which of course keeps costs down and makes things generally more DIY friendly.  Labs had a custom driver designed, 12Pi uses that driver but adds cooling and other variations on it, Bassmax sure isn't using low power eminence drivers.  Not dissing eminence, I have no issue with them, but I'm sure specs could be better with a higher output custom driver specific to the design.
I know the T48 does not perform quite as well as a Danley TH115 in terms of low extension, smoothness, and overall impact, but the difference in sound quality is nowhere near as great as the difference in price.  T36 should be a similar story.  I really doubt it could hang in there with something like a Bassmaxx Deuce, Lab, 12Pi etc in overall output and in lowest distortion figures but who cares when you can have a fleet of them at a fraction of the price?  Most people will benefit more in the extra $$ to invest elsewhere in their rig.
BTW, nicest kick drum I ever heard was on an Adamson line array.  Adamson rigs are bloody expensive but I have yet to hear someone complain about their recent stuff.
My 2c.  Josh what is your intended use?
Jeff
Les Webb
« Reply #5 on: October 24, 2007, 10:31:10 pm »
To each his own I guess. I've heard very few line arrays with decent sound.  Most of these were undoubtably due to operator error as I've heard a few of them sound really good and the same line arrays sound like complete crap somewhere else.
When MercyMe came through the local Civic Center their kick drum was excellent but the rest of the array was spotty at best, unitelligible at worst.
Went to an ATF event at the Dallas Arena with Skillet, Flyleaf, Grits, and Kari Jobe as worship leader.  Everything from Worship music to Metal to Rap. Sound was complete crap for most all the event. Huge line array and PM 5D's everywhere.
Back to the shootout Very Happy
Comparing sizes in horn subs must be done IMO to have equality in results.  I could build a 60" wide Titan 48 with 4 15" speakers and call it a single sub.  It would blow away most anything out there.  But you would need a forklift to move it.
The 12pi is a great sub, but it is almost exactly twice the size of a Titan 48.  It has two 12" Eminence drivers the Titan 48 has a single 15" Eminence driver. To compare them equally would be to compare 2 to 1 IMO.  Power handling, smoothness, and lower extension all start to equal out at this stage.
That's my .02 cents
Les
peter.golde
« Reply #6 on: October 24, 2007, 10:54:52 pm »
Jeff Babcock wrote on Wed, 24 October 2007 14:51
...  T36 should be a similar story.  I really doubt it could hang in there with something like a Bassmaxx Deuce, Lab, 12Pi etc in overall output and in lowest distortion figures but who cares when you can have a fleet of them at a fraction of the price?  Most people will benefit more in the extra $$ to invest elsewhere in their rig.
lb for lb, volume for volume, drivers for drivers, the T36 can HANG in there with any of the above mentioned subs. The differences between them are small, they all have great performance. The difference in cost is debatable. Pay more money up front for a name, better return on investment if planning to sell, DIY start making money right away with little investment, use for firewood when done.
BTW, kick doesn't come from subs, with these monsters of clean low output (all subs mentioned), you better have some kicking midbass, single front load 15's don't cut it.
"You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer" - Frank Zappa
Wayne Parham
« Reply #7 on: October 25, 2007, 01:08:21 am »
Les Webb wrote on Wed, 24 October 2007 21:31
We would have measured doubles if we had time.  Maybe next year we'll schedule two hours per box so we can do multiples.
To compare a pair of Titan's, use the chart of a single Titan and add 6dB if comparing at a constant voltage level or 3dB if comparing at a constant power level.
Be sure and compare SPL and distortion at max power levels too.  You'll notice that the differences increase as power levels are increased.
Ripple will smooth some when using a pair of Titans, but if previous measurements are any indication, I think you need more than a pair of Fitzmaurice basshorns to get mouth size up enough to really see much smoother response.  So I think response shape will be about the same.
Wayne Parham
π Speakers
PiSpeakers.com
josh cohen
« Reply #8 on: October 25, 2007, 01:55:26 am »
im with les on this one.
keep in mind that my market is mainly EDM (electronic music) shows, specificly house music and drum n bass.. a few other co-horts of mine from a :flame:dj:flame: forum that play/produce events of the same style have nothing but good things to say about the 36's in pairs, quartets, or ... sextuplets?
right now price is the key. i can have 2 tuba 36's signed sealed and (picked up) for the cost of 1 jtr growler. (and i can have all the business handled within the great state of louisiana)
if i was doing more LIVE sound reinforcement the growlers would remain my first choice, especially with their compact size and huge sound, but right now my market is growing faster than i can upgrade to growlers.
Josh Cohen
New Orleans, La
504.231.2030
Wayne Parham
« Reply #9 on: October 25, 2007, 10:38:42 am »
I think both the Fitzmaurice and Growler subs are excellent products for their intended market.  They're perfect for medium size shows that are larger than what direct radiators can handle but smaller than outdoor gigs or large arenas.
JTR is a commercial product, and with that comes warranties and product support.  Their products are cut out on a CNC machine and assembled by the factory.  A sound company can pick up the phone and call Jeff, and he'll provide before and after sale support.
Fitmaurice subs are DIY, which is a little bit different market.  The people building Fitzmaurice boxes are do-it-yourselfer's, like the people building LABhorns or some of my speakers.  They're looking for bang-for-the-buck, and are willing to trade sweat equity for it.  I think the authorized builders and flat pack kits make a sort of crossover segment, and that's cool too.
Both Fitzmaurice subs and Growlers are fine products for their intended markets, in my opinion.
Wayne Parham
π Speakers
PiSpeakers.com
Pages: [1] 2 3  All   Go Up
Page created in 0.021 seconds with 14 queries.
