Pages: 1 ... 13 14 [15] 16   Go Down
Author Topic: JTR Speakers "Growler" is Going on a Road Test  (Read 72383 times)
Jonathan Ladner
Re: JTR Speakers "Growler" is Going on a Road Test
« Reply #140 on: October 21, 2009, 05:22:53 pm »
Hey Jeff,
It will be at the Jackson County Civic Center in Pascagoula, Mississippi.
Here is a map to the venue.
http://maps.google.com/maps?hl=en&ie=UTF8&cid=0,0,49 41075417786904448&fb=1&hq=Civic+Center&hnear=Pas cagoula&gl=us&daddr=2902+Shortcut+Rd,+Pascagoula,+MS +39567-1842&geocode=9558998666610957066,30.381571,-88.53 1376&ei=uHbfSpzgAc7X8Aai6sxk&ved=0CA0QngIwAA&z=1 6
This will be a fairly large carnival ball with over 1000 in attendance.  I can give you more specs on the venue and desirable spl levels if you need.
Let me know your thoughts and if this is feasible for you.  I can probably make this available to anyone in the Gulf Coast region who has been wanting to hear a demo of JTR speakers.
Jonathan
Jonathan Goodall
« Reply #141 on: October 22, 2009, 04:04:19 am »
You don't export do you?  I could try a pair out for you "down under" and see if they still work upside down  Laughing
Jeff Permanian
    • http://www.JTRspeakers.com
« Reply #142 on: October 23, 2009, 10:52:44 am »
Shoot me over the specs.
Jonathan Ladner
« Reply #143 on: October 27, 2009, 02:53:03 pm »
Hey Jeff, Did you get my PM?
Jeff Permanian
« Reply #144 on: October 27, 2009, 07:59:40 pm »
Jonathan,
I'll PM you about the event.
Jeff
Jonathan Ladner
« Reply #145 on: October 27, 2009, 10:53:04 pm »
Great, I will have monitor world covered then.  Is there anything specific you will require for FOH or do we just need to provide mixer, efx processing, etc.?
Anyone who is able to attend this event is welcome.  Please provide me your contact information so I may put your name on the list.
Thanks
Jonathan
Jeff Permanian
« Reply #146 on: October 28, 2009, 02:54:21 am »
Will do Very Happy
Kevin Unger
Re: Evan vs. the Growlers, round 1
« Reply #147 on: November 03, 2009, 08:47:46 pm »
Bennett Prescott wrote on Sun, 16 December 2007 16:57
Richard Rajchel wrote on Sun, 16 December 2007 05:01
The key though is that when you use 2 horn loaded cabs together they get a 6dB boost. So instead of 100 dB sensitivity they actually now have 106 dB as a pair.
When you use ANY two cabinets together, within 1/4 wavelength of each other, and you also apply the same power to both of them, you get a 6dB increase in SPL. 3dB is from cabinet coupling, 3dB is from doubling the power (if you had an 8 ohm sub connected to an amplifier capable of delivering 1000 watts at 8 ohms, and you connect another identical sub to the same amp channel, the amplifier now provides 2000 watts into what is now a 4 ohm load to be "shared" by both subwoofers, so each still gets 1000 watts).
The benefit of a horn is increased bandwidth due to the horn mouths coupling (when using multiples)
Just thought I'd throw that in there.
Jonathan Goodall
« Reply #148 on: November 05, 2009, 01:02:00 am »
Jonathan Goodall wrote on Thu, 22 October 2009 21:04
Seriously though, would you export to New Zealand? and would you have any idea of the freight costs for say a pair?
Cheers Jonathan.
Adam Whetham
  • Grand Forks, ND
« Reply #149 on: November 11, 2009, 10:33:38 am »
Jeff... where did your website go? I'm getting a register.com splash page when i go there...
-I practice safe excursion on the weekends.
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." -Paul Neal "Red" Adair
Pages: 1 ... 13 14 [15] 16   Go Up
Page created in 0.054 seconds with 21 queries.
