Author Topic: 15W Ceramic Globes in Blue & Red  (Read 1539 times)
fierceaudio
« on: September 11, 2007, 07:41:40 PM »
Need to help a lampie find 15W Ceramic Globes in Blue and Red.  They are for a set that is being installed Thursday.  Only able to find at most 10W transparent.  Tried friends in Minneapolis, Portland, Seattle, Carolina's and Google. Any idea who might make them?  Who might sell them?  We've tried about 15 suppliers, so any advice or direction would help.  Thanks.
Brian Ship
Re: 15W Ceramic Globes in Blue & Red
« Reply #1 on: September 11, 2007, 11:48:41 PM »
15w - what shape of lamp in question but important to know is not a normal wattage for as called a ceramic coated or otherwise inside frosted lamp from a premium brand in colors.
Can have your lamps dipped, or otherwise have to move up to 25w, or down to 11w.  Halco http://www.halcolighting.com/ and Bulbtronics www.bulbtronics.com are amongst many - good suppliers of such lamps.
Otherwise, Midway is a manufacturer that makes 11 Watt S-11 shaped lamps - available thru Bulbman and most other normal lamp supliers.  Midway is a good company for colored lamps.  Action Lighting would also be a good supplier specilizing in smaller wattage colored lamps.  http://www.actionlighting.com/index.asp
(Again - most lamp suppliers above and beyond the above sources can get either S-11 or S-14 lamps in 11w, 15w possibly with some effort, or get the lamps professionally dipped for you.  Such dipping is possible dependant upon how dogmatic the 15w need is and bulb shape is, it's possible with some lead time to get the lamps dipped for you - won't cost an arm and a leg but will take a bit more lead time.)
Avoid dipping the lamps yourself - nasty stuff the Rosco lamp dip, but if you do, make sure them lamps are absoluetely cleaned or you will get oil from the skin problems.  Even after this, nasty stuff - some experience with this stuff.
Another option is to do clear 15w lamps and something like #16925K22 from McMaster Carr http://www.mcmaster.com/ which is a colored slip on safety sleeve for a A-19 lamp.
Craig Leerman
Name Policy
« Reply #3 on: September 12, 2007, 12:55:13 AM »
You need to use a real name to participate here. Go to your profile and put your real first and last name as your alias or your posts will be deleted as per the rules clearly posted at the top of each forum.
Craig Leerman
Forum Moderator
Page created in 0.026 seconds with 20 queries.
