Author Topic: Midas Direct Out question  (Read 2463 times)
(Brian) Frost
« on: September 06, 2007, 02:39:16 pm »
Working on an event coming up using a midas heritage 2000.  I will be doing a simple multitrack recording by taking the direct outputs of each channel.  These should be line level, on XLR, coming out of the board.  Am I correct?
Frost
Owner, Narnia Productions
www.NarniaProductions.com
Chicago IL
Good is good but not as good as better
Thom "Fig" Fiegle
Re: Midas Direct Out question
« Reply #1 on: September 06, 2007, 02:48:51 pm »
From Midas' website on this page:
http://www.midasconsoles.com/h2000-specs.html
Direct Outputs: Every input module is fitted with a direct output as standard with its own level control and front panel switching which selects the source from pre / post equaliser.
XLR output count of 89 as follows:-
44 input channel direct outputs
12 audio group outputs
12 aux outputs
8 matrix outputs
3 master outputs
3 solo outputs
6 local outputs
1 talk external output
HTH,
Fig
The easiest thing to do is the thing most easily forgotten.
Phil LaDue
« Reply #2 on: September 06, 2007, 02:51:44 pm »
They are XLR and according the promotional material I have:
Direct outs are Front panel switchable(pre/post) and have level control.
(Brian) Frost
« Reply #3 on: September 06, 2007, 07:33:20 pm »
thank you, just wanted to make sure I dont have to bring 24 mic preamps.
Frost
Chicago IL
Page created in 0.036 seconds with 21 queries.
