Quote: |
Chris
I'm certainly no electrician (so I won't comment on safety), but I have not seen you refute the illegality of your method.
Is the electrical procedure in question legal to perform in your area?
My method is that of using an extension cord... you do so at your own risk, you can start a fire with an extension cord if you are clueless...
Is an extension cord illegal?
NAY...
Here are the technical details....
After checking any other devices on either of the 2 circuits, best if there are none for the super safety people, but if there are some, your electrical knowledge will confirm or deny the saftey of each device electrically in such arrangements... now that being out of the way... 2 15 or 20 amp circuits supplying a single 30 amp load
(current stays the same in a series circuit) but in a parrelel circuit voltage remains the same, thus safely increasing available CURRENT to amplifier, NOT CHANGING WIRE SIZE IN WALLS, OR BREAKERS..... AND PRESENTING ZERO SAFETY HAZARD..
Now do we see the light? now we see how silly all of the complaints are with this knowledge?
Legal? no alterations to building electrical systems exist, infact, this method is MORE SAFE! than using a single 15 or 20 am oultet for a 30 amp load...
