Evan ol buddy! I knew you wouldnt be late.... ok lets look at your melt down... unfortunately I am limited to a full diagnosis from a picture... Now im good, but not that good, so i will point out the obvious...
first of all, from the looks of the pic,
loose connections to a sub panel or similar melted down.... Loose connections are most likely because the burn out is in one area, but loose connections are only the most likely, without being there, its a whole different story...
No company will ever attempt diagnosis from a picture, lets be real here...
but I say, good questions Evan gets D+
Quote: |
No, he suggested to build a 30 amp to dual 20 amp adapter, even dumber...
Since we have a judgement call here, what exactly do you mean? and what did I mean? since 'dumber' is used, what are the technical details behind 'dumber'?
try to be educational in your response please... its ok if you cant answer, I understand
