Author Topic: A Stand advice, suggestion, review request  (Read 1256 times)
Tony "T" Tissot
    • http://www.4dbsound.com
« on: January 24, 2007, 10:48:58 pm »
I need a pair of entry-level stands for 14" (light duty AL) truss.
Anyone have experience/pointers/warnings with these:
Just hanging (mounting) about 220 lbs. including truss, cable, fixtures (at 12 foot trim) span from 18 to about 27 feet.
from http://www.stagelights.com/truss.htm#Steel%20Crank%20Up%20St ands
(and other sources)
CU-15 (15 feet) (3 flat legs - All steel)
  Heavy Duty Steel Crank
  up Stand with locking
  winch and aircraft cable.
  300 lb. Capacity
Aluminum - SLC 150 (4 legs - all aluminium)
 Max. height: 16' 5"
 Max. load: 220 lbs.
 Base w / outriggers: 6' 6"
(don't need the usual rigging warnings, weight distribution discussion for now)
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Rob Blohm
Re: A Stand advice, suggestion, review request
« Reply #1 on: January 29, 2007, 02:39:30 pm »
Since you're using actual truss and putting a decent load on it, I'd stay away from any of those super cheap DJ truss stands (ADJ comes to mind). I'd go with something with outriggers and a winch and steel cable. There's a lot of different ones out there, and I haven't tried them all, so I can't really make a recommendation, but I'd think as long as it meets your trim requirements, load requirements, and isn't a cheap DJ setup, you should be ok.
Tony "T" Tissot
« Reply #2 on: January 29, 2007, 04:06:25 pm »
Makes sense.
Mike Pyle is getting me some of the mid-capacity Global-Truss stands.
MNGS
Page created in 0.019 seconds with 19 queries.
