Have you tried looking at the manufacturer's web site? The Xi-1152A/64 page
http://www.electrovoice.com/products/32.html has direct links to the Dx38 settings and the RACE files for that speaker. EV's Tech Library
http://www.electrovoice.com/tech-library.php?pt=3 also contains such useful information as rigging information for the Xi series, the Xi Arrayshow program, Xi series RACE files, EASE files and even some applications diagrams.
Since it didn't seem to be stated, what is your experience with rigging, installing and tuning sound systems? Knowing a little more about you and your experience and abilities would be useful. For example, if you have never used something like Smaart and never tuned a system, then it might make sense to hire someone for this work who would let you work with them and learn from that experience. The same with moving and rehanging speakers, that is best left to someone with rigging experience. You may be, it's just not real clear what your role and background are.
Quote: |
I then looked at the way that the PAS speakers had been plugged in. They had ignored the PAS processor and run a full way signal to both the high and low frequency speakers. Luckily, I found and fixed this before the speakers were used.
You said the speakers were the PAS PI15-1, which is a full range speaker with an internal passive crossover, therefore no biamping or separate high and low inputs. So either they are actually the PI15-2.2 or they should be wired full range.
Given that three Xi-1152-64 speakers in an array would be at least a 180 degree horizontal pattern, I'm a little surprised that you need side fills. You haven't provided any information on the room itself such as dimensions, where the audience is, what height the speaker are at or what the room finishes and acoustical environment are. So it is a little difficult to provide much of any response regarding coverage and aiming. In fact, without this type of information I'm not even clear why there are any side or rear fills.
