Tom Bourke wrote on Fri, 23 March 2007 16:37 |
Sorry to say the first pic IS both on white. They are that different. They start to even up once you add gel to the 500. The "white" of the LED is useful but not really white. Here is a pic of the set up I used. The wall is about 12 to 15 feet from the cans. Keep in mind I set the camera to white balance on the 500 watt par can.
that detail.. "white set to balance the 500 watt..." is I htink very importand.
IF you where to set teh cammera to white = a white sheet of paper, we would see the "real" colors.
in this case, as we have set one to be "white" and looked at the result- what we are seeing is the differantial.
The led looks blue, but is it??? or si teh 500 watt just kinda red, so that was removed from the picture as a whole? we have no way of knowing from the picture. We could for example have set teh white ballance to teh LED fixture , then the 500 watt would be really red.
thanks for the photos though they tell alot about what is going on . I am just waiting for soemone here (craig???) to get a really cool working design that is LEDS with source 4 lense and powerfull LEDS bulbs, like the 1 watt lexons then I am off to the races.
On that note, I remember craig mentioning that the wide and extra wide ones work the best for color mixing, and hiding the leds. however they spread teh beam to wide. - consider useing a narrow beam LED with teh really wide lense?
Kev.
