For small gigs and a personal bass rig, I'm getting ~ 122dB @ 27.5Hz Thats not insignificant. I never said the rig was for 6000 people. If I was doing that size gig there is only one practical choice for 20Hz output that I know of and quite a lot of them would be necassary.
Less than 118dB @ 20Hz is enough to make the roll up doors in our warehouse rattle and make the windows in the loft osscilate violently, as well as the floor.
The Sealed subs would be for a similar purpose, or near/midfield monitoring. 110dB @ 20Hz is not insignifican't insignificant quite impressive for something that is a mear 4cu' sealed sub.
Are you of the oppinion that if Clean undistorted 20Hz isn't available at SPLS greater than XdB that its useless to allow the sub to go that low.
I figure If I'm an order of magnitude or two above the threshold of hearing then I'm doing Ok.
It would be nice to have enough headroom that low to implement some sort of Equal Loudness curve, A little more easy to acomplish on a small scale. Not in a 6000 person PA Unless your DEATHCLOCK!!!!! and happen to be the 12th largest economy in the world.
Who says I'm not a hobbiest.
I'm thinking that a 28 X 28 X 14 4X Lab 12 linkwitz transform cab with at least 2kW of amp behind it would be a Sweet 5 string bass rig Sub, Syth Sub, Home theater sub, or studio sub. 110dB @ 20Hz may not be PA worthy but Its about all you can expect out of something so small.
Anyhow all that said, and were off track. I guess my point is most pro Amps Don't Highpass until 5-10Hz, why would an amp designed as a "Subwoofer amp have a builtin high pass around 25Hz????
Antone-
