Pages: 1 [2] 3   Go Down
Author Topic: The 35 hz cut off ?  (Read 11538 times)
Phil Pope
    • http://www.apacheacoustics.co.uk
Re: The 35 hz cut off ?
« Reply #10 on: December 22, 2006, 02:10:13 pm »
if LABS don't go low enough for you there are two choices:
make some boxes to go under them. your options would be bandpass boxes like the Funktion One Infrabass; something like the danley PB12 (or see Walt's stepped horn); or a very long piece of sewer pipe with a long excursion driver on the end. other options are either too expensive or too large IMO.
try a Waves Maxxbass. some people are sceptical that it's not REAL bass but sounds good to me. for example 20Hz is reproduced as a combination of 40Hz and 60Hz tones so there is still a lot of air being moved. At the gig I did last week my 40 Hz boxes sounded flat to 25Hz with the Maxxbass and a little room gain. at about $300 it is certainly a lot cheaper than several extra speakers and amps to occasionally reproduce sub 35Hz material.
Phil
Antone Atmarama Bajor
« Reply #11 on: December 22, 2006, 06:53:17 pm »
Yikes Maxxbass is using side band generation, that means you get.
20Hz, 40Hz, 60Hz, and 100Hz Simultaneously.  That doesn't sound very harmonious to me!?
Antone-
Mike {AB} Butler
    • http://www.3alchemy.com
« Reply #12 on: December 23, 2006, 08:02:40 am »
Phil,
My point was that for live work.. it would be better if one didn't try to reproduce below 30 Hz... for the sake of most, if not nearly all buildings and fixtures out there. It's a potential liability issue that is my concern.
Regards,
Mike Butler,
Principal, Technology and Operations,
Dascott Technologies, LLC
Bennett Prescott
    • http://www.adraudio.com
« Reply #13 on: December 23, 2006, 10:39:37 am »
With subs, it's pretty much:
* Loud
* Low
* Small
* Cheap
Pick any two.
-- Bennett Prescott
Director of North American Sales
ADRaudio d.o.o.
Cell: (518) 488-7190
"Give me 6dB and I shall move the world." -Archimedes
Mike {AB} Butler
« Reply #14 on: December 23, 2006, 03:59:44 pm »
I've been able to get to three out of your four.. Wink
Small, Cheap, Low.. plus light in the same package for a single 18.
Sorry. couldn't resist.. Very Happy
Regards,
Mike Butler,
Michael 'Bink' Knowles
    • http://www.binkster.net/index.shtml
« Reply #15 on: December 23, 2006, 06:00:04 pm »
Mike {AB} Butler wrote on Sat, 23 December 2006 12:59
Cheap? Only if you undervalue your shop time!
Shocked
Cool
-Bink
www.binkster.net
Mike {AB} Butler
« Reply #16 on: December 24, 2006, 07:54:58 am »
Just under 8 total hours per box. And remember, at VA shop labor rates, that's a LOT lower $$ than the SF Bay area.. Sad
I DO confess a LOT of hours went into making it manufacturable, though..  Very Happy  The first article took well over 15 hours to walk through the assembly process (ever try building when the instructions haven't been invented yet? Twisted Evil ), implement acceptable grilles, as well as damping, testing, etc. Actually pretty low time for a first article, IMO.  Cool I'm not a newcomer to box building, either (started diddling with this as a kid in 1970).. but this is decidedly the most elaborate front loaded box I've ever come up with.
I will post the results - with the cost scoreboard.. once I get the first 2 completely out of the gate..
Regards,
Mike Butler,
Bennett Prescott
« Reply #17 on: December 24, 2006, 02:40:47 pm »
How low and how small? Just curious.
-- Bennett Prescott
ADRaudio d.o.o.
Mike {AB} Butler
« Reply #18 on: December 24, 2006, 04:24:53 pm »
See My PM to you..
Regards,
Mike Butler,
Bennett Prescott
« Reply #19 on: December 24, 2006, 09:10:30 pm »
Seen!
-- Bennett Prescott
ADRaudio d.o.o.
Pages: 1 [2] 3   Go Up
Page created in 0.071 seconds with 18 queries.
