Evan Kirkendall wrote on Fri, 03 November 2006 23:16 |
Jim Smith wrote on Fri, 03 November 2006 22:50 | Can you expand upon how you were using/powering these.We've had great results w/ this box.
The guy had a Yorkville amp powering them. I have no idea how much power each box was getting. I was just sitting in mixing one of the bands. It was indoors for about 400 people. I just couldnt get anything out of the boxes past 20'.
Quote: | Are you serious when you say you are using a bridged plx3002 on the 608's you're selling & clipping it on every hit !! Holy crap Evan.....I'd recommend when you get your new subs to consider less power to ea. box & add boxes for the most impact as well as long term reliabilty.
Jim
Nah. Peak power man! I dont clip on every hit. Just whenever I start getting into things. I try to keep clipping to a min. They've handled the power just fine.
The UCS1's are 1000w program and 2000w peak, so they can handle the 1500w with no problems. I believe Jim B was running a bridged PL236 into them.
Combat audio... Good Times. Never enough power. Ive gotta start triamping the TRX's soon. Im running out of headroom with the plx2402 bridged into them. So, I figure to get the most out of the tops Ill triamp. WOo.
Evan
Well that's a pretty vague way of determining any kind of reasonable assesment of how "anything" performs IMO
I can tell you this from a good bit of experience using these boxes.They absolutely will go well beyond 20' even powered up at program ratings.
Now....the UCS1 will definately put out more than the 608 using the same power for a few reasons,but there really isn't a huge differance in what they can take so you still need to be aware of how hard you are clipping the amp to them.
You initially claimed to be clipping the amp on every hit using the plx3002 & 608's & even if the damage isn't immediate you are going to decrease the drivers life significantly at near peak power & clipping the amp at whatever amount it really is.
If you are going to use that kind of power best thing to do is stay away from clipping.
If you really want to add some serious balls to your low end output add boxes.
