Aux-driven subs are, for practical purposes, best done with a digital speaker processor. Drive the mains with one or two inputs of the processor and the subs with a single input. Since you (usually) don't dedicate a 1/3-octave grahpic EQ to the subs, you'll have some parametric EQ control should you need it. If you're stuck using an analog crossover to low-pass subs, then it would be good to have something for some EQ control, again should you need it. But not totally necessary. 20hz to 80hz, where most subs low-pass anyway, is 2 octaves, so it's up to the user's needs as to whether or not they will need EQ. On our MX-8750s, I have 6 bands of parametric EQ on the inputs and 5 bands on the outputs. That's 11 bands of EQ, plenty of EQ for 2 octaves of sub energy (I have been fussed at by a couple of bands guys for not having a graphic EQ on the subs and that tells me that the guy doesn't understand the nature of parametric EQ.
Keep in mind that the speaker processors will usually have comp or limiting abilities as well. I've said this before and I've been met with much disagreement, but in this day and age of inexpensive digital processing and with the performance that even small club providers are expected to deliver, there's no reason to use an analog crossover anymore. It's fine if you do and get acceptable results for whomever you're responsible to (yourself, your band, employer, etc.).
Geri O
