Hi Peter,
I never really consider the 30Hz stuff; most of the energy is in the 60 to 80Hz region so that’s where I consider the pattern control will have the most noticeable effect.
Being a realist I would tend to agree. But something weird happens at the extended lf level. Those of us who have used Tom Danley's ServoDrive product, notice that the mid-range level seems to appear cleaner. Also people tend to turn the whole system down. If you ever meet Joe O'Herlihy (FOH U2) he will say the same thing. It appears to be something to do with the ear trying to add in frequencies and doing other weird phase correction stuff. But very low frequency pattern control is useful in enclosed spaces. Tom Hidley started doing 20Hz & 30Hz rooms many years ago, and they do sound subjectively better.
The problem with a Bessel array is the loss of efficiency caused by inverting the polarity of one of the boxes and running 2 at 1/4 or 1/2 power (what ever it is). I think you would be about 8dB behind.
Yes something like 7 or 8. "No such thing as free lunch". So that if you want absolute maximum output then this is not the answer. Hopefully people don't run their system at full limit all the time. (Hm mm) Bessel is essentially for smoothness when you can afford the power loss. Check out the Appendix of Don Keele's paper, and have a look at the charts comparing a 5 box block and a 5 box Bessel at +/- 45 deg off axis.
Of course if you are operating at less than max level then a 5 box Bessel is a great way of getting smooth coverage. If you also add the extra 3 behind as a pseudo cardioid things get really interesting. Though I still like the 2x4 end-fire that I showed previously. With the proviso of having enough front of stage area. In the bigger events, then we are really looking at a spaced or simple line. At a festival situation you might have environmental noise considerations. So keeping LF away from houses and offices should be a consideration. I would also think a horizontal line would be good for street fairs. Keeping it off the buildings and sending it down the middle of the street. Cardioids are great for stopping LF going backwards in to areas behind the stage. One place they really can make a difference is, with outdoor band shells. Hollywood Bowl type of venue where they have strict environmental noise limits. These concepts are not just for the monster sound companies. A two box or three box cardioid, at centre stage or wherever, is very useful for a smaller company doing corporates or similar. Just think of the success people have with Nexo sub product. Of course you don't need to be a Nexo or whatever owner to benefit.
Pragmatism tells us that, maybe in many situations, two stacks either side of the stage is the only viable solution. But these various types of array, are a great tool to have ready and waiting.
Iain.
