Author Topic: IEM Mixes with effects  (Read 3507 times)
Jason Grooms
« on: February 17, 2011, 06:56:55 pm »
How are you all going about creating IEM mixes with effects?  It's easy enough to create a montior mix using a pre-fade AUX send however, I've never figured out how to add an effect to this.
I would really like to create an IEM mix for my band and be able to add reverb (for example) to the vocal(s) (or whatever other effect) but how?  I can't believe everyone's IEM mix are dry, so how are you all doing this?
« Last Edit: February 17, 2011, 06:58:45 pm by jgrooms »
Bob Charest
  • Lab Lounge
  • Westbrook ME, USA
    • Bob Charest Band
Re: IEM Mixes with effects
« Reply #1 on: February 17, 2011, 07:31:12 pm »
When I was using the Crest XRM, I was out of inputs, so I sent an aux from FOH (on vocs and a little on horns) back to a reverb and sent the wet signal into the common inputs and adjusted to an agreeable level.
Now with an LS9 a send to reverb from vocs and horns is returned back to the various mixes - much easier and more configurable.
Best regards,
Bob Charest
Thomas Lamb
« Reply #2 on: February 17, 2011, 08:44:38 pm »
Return your fx into a Chanel instead of a return and turn it up in those sends butNOT back to itself.
bigTlamb
George Dougherty
« Reply #3 on: February 17, 2011, 10:53:49 pm »
This is one place where Software Audio Console rocks many other options out there.
I patch an instance of a reverb plugin across the output of each of my iem mixes.  Just enough wet blend to give the mix a sense of space but not so much that everything gets smeared around.  The reverb is then perfectly tailored to each iem mix.  I also have a few vocalists that use the Rolls boxes with the more-me dry mic input.  If they still want a wet vocal I use an aux on the channel instead and route their vocal only into the aux and not the monitor mix output then season to taste.
On an analog board, ditto, back into a full featured channel so you can route to all the auxes you need.
Sean Chen
    • Pristine Audio
« Reply #4 on: February 18, 2011, 10:58:02 pm »
What mixer are you using? On A&H Mix Wiz3, I can adjust how much effect to add to Aux 1, Aux 2, Aux 3, and Aux 4.
Pristine Audio
Authorized dealer for Allen & Heath, Countryman, Danley Sound Labs, Dynaudio, Electro-Voice, Gator Cases, HK Audio, K&M, Mackie, MiPro, RCF, Shure, Yorkville
www.pristine-audio.com
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #5 on: February 19, 2011, 12:30:29 am »
I can't imagine using a reverb across a mix.  It can occasionally sound good, but often it's not good at all.  (Running a full mix through is a good way to test reverbs - most sound fine when fed one or two channels, but sound a complete mess when fed an entire mix.)
Jason Grooms
« Reply #6 on: February 19, 2011, 01:07:06 pm »
I have to use a variety of mixers depending on where we are playing (size) however, that is going to change as I just purchased an Allen & Heath iLive system using an IDR-16 so I can pretty much take that anywhere, so let's use that as an example.  Considering I literally just purchased this I may not be able to speak to specifics about the board until I play more with the it however the routing on these systems is pretty extensive so I am sure it will be able to do whatever you all propose.
I am just looking for general concepts on how this acheived.  So far I am hearing a) return the effect to a channel and send the effect to the AUX of the IEM mix or b) place a reverb on the entire IEM buss and adjust to taste
Thanks for the feedback so far.
« Reply #7 on: February 20, 2011, 01:06:31 am »
You need to get a mix to the effect and then get the output of that effect into the aux that feeds the monitor.  For IEMs a dedicated (for the IEMS) effects send would be a very good thing.  I'm not familiar with the iLive, but my guess is you have plenty of auxes and a spare FX, and that effect return channel inputs can be sent to auxes like any conventional mono input.  Send the effects return to the Aux that feeds the IEMs, and no other aux.
You treat the effect for the IEMs just like you would for the house mix, only you return it to the IEM mix rather than L/R.
Have fun, good luck.
Tim Mc
George Dougherty
« Reply #8 on: February 21, 2011, 06:52:13 pm »
It's used very sparingly and the intent is to just take the dry edge off the mix and put it back a sense of space.  Any amount of obvious reverb is way too much.  I've found many performers using iem's for the first time find a dry mix straight into their ears to be very unnatural.  I also use small to medium size room reverbs rather than big plate or hall reverbs.
John Sulek
  • Toronto Canada
« Reply #9 on: February 22, 2011, 06:36:13 pm »
You might consider audience mics.
Depending on how loud the stage is and how much isolation you have from the main PA, they can add a sense of the performance space.
If you have a lot of open vocal mics, audience mics will be less effective.
Page created in 0.043 seconds with 21 queries.
