Author Topic: Moving Head Mounting Question  (Read 10454 times)
Chris Hunt
« on: February 17, 2011, 02:54:05 pm »
We have 4 10 ft' vertical truss that we line up behind the band and then put poles from truss to truss to hang our movers on.  I saw at a church service I recently went to where they suspended a mover from what appeared to be a pole attached to ceiling truss hanging straight down.  Anyone know what I'm describing?  I want to do this on the 2 inside movers to break up the vertical placement and provide some different scene possibilities.  Asside from making them myself, anyone know who might sell these?  Thanks!
Chris Hunt
Limelight - FOH
Thomas Bishop
Re: Moving Head Mounting Question
« Reply #1 on: February 19, 2011, 02:13:53 pm »
That would be Light Source drop downs:
http://www.thelightsource.com/products/45/view
I just bought a few of them myself.  You'll need a clamp at the top and a clamp and pipe at the bottom in order to hang a moving light.  I don't have any closeups of the rigging, but here's a picture of the outcome:
http://www.nomadicpro.net/photos/circasurvive04.jpg
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #2 on: February 20, 2011, 01:14:44 am »
What you are referring to is called a "side arm". They are used to mount a fixture on a vertical or horizontal pipe.  Here is a link with a few examples from City Theatrical.
http://www.citytheatrical.com/act-ssidearms.htm
The picture on the left of that linked page shows a hanging arm that would be perfect for your application. It has 2 half couplers at the top to secure the drop down arm to  a truss.
The "standard" style side arm in the biz is basically a C clamp with a short length of pipe mounted to it, and a sliding "T" that slides over the pipe and allows you to position the fixture any where along the pipe's length.
Altman, and others all make them.
Here is a pic of the "standard" style
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Royce Covington
« Reply #3 on: February 20, 2011, 08:37:00 pm »
i believe both responses are missing the "moving light" portion of the question.  as none of the suggestions would be suitable for such an application.
if i understand correctly, you are wanting to suspend the movers below the truss, perhaps, several feet?
if so, i have seen this done in larger productions where a "pipe" apparatus was used to suspend movers from the end, side or below a truss.  often in a "T-bar" configuration, attached to the truss with swivel-clamps, or similar.
i know of no direct source for such a product, as the device was often custom-fabricated by the provider.
R~
"If you love what you do, you'll never work another day in your life..."
- Confucius
Thomas Bishop
« Reply #4 on: February 21, 2011, 09:40:39 am »
No, I'm not missing anything.  I hung MAC250's off the Light Source drop downs using the method I described.  I also posted a picture of the rig.  I'll try to get a closeup of the entire rigging later today, but it's a clamp to the truss, the drop down, a clamp at the bottom, then an 18" horizontal pipe.  The light clamps to the pipe.  It makes an upside down T.  Originally I had considered using a pair of these with custom length pipe.  I would say that if going more than a couple of feet this will be much more stable.
Chris Hunt
« Reply #5 on: February 21, 2011, 12:26:35 pm »
Perfect, thanks guys!  Exactly what I needed to see.
Chris Hunt
Limelight - FOH
Royce Covington
« Reply #6 on: February 21, 2011, 04:15:31 pm »
at closer look of the 'drop-down' it appears as though they rate it at 600#, so, i suppose if/when used as you describe, it would be sufficient.
initially, that device reminded me of having seen someone use 1/2" threaded-rod in a similar clamp to clamp arrangement...
R~
- Confucius
Thomas Bishop
« Reply #7 on: February 21, 2011, 06:19:33 pm »
Yes, threaded rod would be scary.  600 lbs should be fine for small movers, even at a dynamic load.  I wouldn't hang VL2500's from them, but MAC250's are no problem.  Speaking of threaded rod, though, I did have to use 1/2"-13 rod to attach the bottom clamp to the drop down.  Just an FYI for those looking at doing this same setup.
James Feenstra
« Reply #8 on: February 22, 2011, 12:33:23 am »
1.5" pipe t bar + 2 fixed 90 degree cheesboroughs + aircraft safety through a drilled hole in the pipe will be fine for any small to mid sized movers
Wouldn't hang anything more than say, 80lbs off it though...for a big mover (ie. Showgun, syncrolite, etc) you'll need something a little more complicated.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Page created in 0.072 seconds with 23 queries.
