Author Topic: Wall box for plug panel ?  (Read 1416 times)
Tom Young
« on: January 21, 2006, 09:51:58 am »
I have been trying to find a wall box that will accommodate a custom 12"W x 10"H (+/- 0.5") plug panel that needs to be perpendicular to the floor. Plug panel will have multipins, XLR's and other connectors. I have a supplier for this.
All I've seen from FSR and Ace Backstage are boxes that have internal elements designed for their slanted panels.
This box needs an attractive hinged (drop) front lid with or without cable cut-outs.  The plug panel will sit 4-6" inside with enough space behind it for terminations.
Any leads ?
TIA
Tom Young
Oxford CT
Tel: 203.888.6217
Email: dbspl@earthlink.net
www.dbspl.com
Re: Wall box for plug panel ?
« Reply #1 on: January 21, 2006, 12:17:59 pm »
Ace makes 2 boxes that do not have angled areas for the plates. They are "flat" ie parallel to the lid.  Neither of these is the size you are looking for (1 smaller and 1 larger) so they may not work if the plates are already existing.  These are the Super pocket and the Super Double wide models.  Ace will custom make plates to go in these (so the screw holes all line up easily) or you can get other manufacturers to do so, and spec the hole placements yourself (ace has these in their catalog)-if they cannot do the particular configuration you want.  We do this fairly often-using Horizon panels in Ace boxes.  Sometimes we do this because Horizon will wire up the multipin on a plate that will drop into the Ace box.  Saves us a lot of time and money.
dB Audio & Video Inc.
Page created in 0.052 seconds with 21 queries.
