Assuming this is a 70/25-volt distributed speaker system ...
If the terminations are housed in the amp rack, use the term block and crimped spade lugs. One side of the strip would be used for the amp output(s) and the other for the field wiring. Use jumpers on the amp side to connect as many field wires as you need.
If the connections are to be made in the field, use standard wire nuts inside electrical junction boxes (with knockout bushings to protect the insulation).
Both methods will allow you to easily troubleshoot the system down the road.
If it's a low-impedance ("direct") speaker system, the preferred method is to "home run" the field wiring directly to the amp(s). No need for butt splices -- cable comes in spools up to 1,000 feet. If you have to run that far, a low impedance speaker system isn't an option.
