Author Topic: Noise when laptops are connected  (Read 4842 times)
Miguel Sousa Magalhães
« on: December 03, 2005, 05:57:23 pm »
Hi
expirience noise when some laptops are connected to mains and to desk. Some times also occurs whem there is a video projector also connected.
Any way of wipe this noise?
Miguel
Chris McDonald
    • http://insec.ca
Re: Noise when laptops are connected
« Reply #1 on: December 03, 2005, 06:05:33 pm »
With my old laptop I had to run off the battery, the power supply was very noisy. Using a DI box to lift the ground might help. Also try USB or firewire sound interfaces rather than the onboard soundcard.
Ken Freeman
« Reply #2 on: December 03, 2005, 08:45:14 pm »
What kind of noise?
Is this a Hum that stays with you? Try using a direct box with a transformer to isolate the signal grounds.
Do you have the input turned up while you are connecting?
ken
« Reply #3 on: December 03, 2005, 09:33:30 pm »
I believe it's not the typical hum noise generated by earth loop.
In hotels there are all kinds of stuff that makes interferences, air conditioned, electric motors etc.
What's is funny is that laptop transformers dont' have earth but noise stops when is running only with battery's
This don't happen in all rooms with all pc's.
We connect the phones out of the laptop to a DI ( usually in mono ) and then send it to desk as a mic.
Ground lift don't solve this. My DI don't have transformer isolation, should be it?
Miguel
Ken Freeman
« Reply #4 on: December 07, 2005, 11:04:44 pm »
I am familiar with the hotel environment.  At least, treat the computers like they are stage gear and keep them on the "Tech" power.
Your note about how they do not make any noise on battery but do when plugged in A/C is a dead giveaway.  I suggest isolating the signal ground using a passive transformer based Direct Box.  I like Pro-Co's AV-1 the best as it can be multipurpose.
Do not, I repeat, Do not lift the A/C ground.  You are asking for trouble.
Ken
« Reply #5 on: December 07, 2005, 11:49:52 pm »
Well most of transformers don't have ground so no lift is possible. I was using a active DI but without transformer isolated. The ground lift did not do any effect.
I don't believe that i will have to carry a super cost Di for those creepy sounds of powerpoint. Well quality is everything
Brian K Tennyson, CTS-D
    • http://www.visitec.com
« Reply #6 on: December 08, 2005, 12:19:07 pm »
New product from RDL (but with RCA's)http://www.rdlnet.com/av-hk1.htm
Or try the Wirlwind pcDI. http://www.whirlwindusa.com/dirbox.html
or RLD STA-1 will balance your audio. If that doesn't do it you can lift the ground on the balanced out of the either of these boxes and it should kill that buggar.
You can't get enough, but enough ain't the test.
Brian Kent Tennyson, CTS-D
Visitec
www.visitec.com
Ken Freeman
« Reply #7 on: December 09, 2005, 01:43:42 pm »
Yes, these are very cool, but dedicated you can't use them as a DI the next day as the AV1 will.  I still think the single transformer based DI with a 1/4", rca and 1/8" input will still be the way to go.
http://www.procosound.com/downloads/av1.pdf
Ken
Simon Clayton
« Reply #8 on: January 26, 2006, 06:19:28 pm »
Ours do. I use a mains adapter that cuts the earth connection to the computer transformer. Works fine.
Bleep, le Jardin Moderne, France
Simon Clayton
« Reply #9 on: January 26, 2006, 06:26:06 pm »
I routinely use an adapter to cut the AC earth in the quoted situation. Why do you reacon it's risky ?
Page created in 0.036 seconds with 18 queries.
