Author Topic: Broad Spectrum Graphics Insertion  (Read 3995 times)
Brian K Tennyson, CTS-D
    • http://www.visitec.com
« on: November 03, 2005, 03:32:01 pm »
I am looking for a graphics insertion device that will insert the same crawling banner or logo on all channels of a television distribution system simultaneously.
Any takers?
You can't get enough, but enough ain't the test.
Brian Kent Tennyson, CTS-D
Visitec
www.visitec.com
Andy Spalla
    • http://www.spallasound.com
Re: Broad Spectrum Graphics Insertion
« Reply #1 on: November 10, 2005, 10:38:04 pm »
All channels is tough. For the local access channel I run, we use the Aavelin MagicBox. It's nice. I suppose you buy a ton of these and insert them on each channel, but that would seem real expensive. Smile
-Andy Spalla
GM DNR Pro
Ken Freeman
« Reply #2 on: November 28, 2005, 08:50:08 pm »
Try this:
http://www.infocomm.org/index.cfm?oID=9042F99D-1158-46EA-8E0 79DA3E5F4E6CE
It is a Chyron piece designed for emergency inserts.
Ken
« Reply #3 on: November 29, 2005, 03:26:45 pm »
Thanks, but it appears that it works like the ChyTV system which means you have to put a unit at each TV. My be practical for smaller systems but not for a large deployment.
Visitec
www.visitec.com
Ken Freeman
« Reply #4 on: December 03, 2005, 08:39:49 pm »
If I understand this correctly, this would go into master control and would go into the modulators prior to hitting the amp.  You would need one per channel, not one per TV.
Ken
« Reply #5 on: December 04, 2005, 11:51:14 am »
If it worksthe way the regular ChyTV system works it would be at the TV.
I will contact someone at Cyron and see if they can fill us in.
Visitec
www.visitec.com
« Reply #6 on: December 05, 2005, 03:25:38 pm »
Here is what I got.
Quote:
Brian,
I was unsure as to the proper answer to your question so I forwarded it on.  Please see the response that i got below.
If there is anything else we can do for you please let me know.
Thanks and best regards,
Gene
----- Forwarded by Gene Sudduth/CHYRON on 12/05/2005 01:50 PM -----
Charles Motta/CHYRON
12/05/2005 01:52 PM
To
   Gene Sudduth/CHYRON@CHYRON
cc
Subject
   Re: Fw: Questions about Chyrons Two Channel ChyAlert Video Emergency and Security Alert SystemLink
Gene,
I guess I am the only one that has any experience in this area.
Chyron is currently providing 25 dual channel ChyTv Video Emergency and Security Alert systems to a Federal Government user with a option of increasing to a total of 60 systems.  The purpose is to give security personal access to a large complex (couple of buildings) to alert via existing cable and internet services any emergency that may arise, ie:  fire, evacuate building, lock down of building, etc.  We have written a customer GUI front end for this specific customer at their request to simplify the entry of information at additional cost.
In general this customer has a 85 channel CATV system servicing a number of buildings.  The incoming RF signals are demoded inserted into ChyTV remodulated and sent out to the respective channels.  The content for the ChyTV is preprogrammed by the security operation using Power Point and saved to a central CPU with ChyTools software.  All of the ChyTv systems are on a common ethernet and are addressable by individual IP address, in groups or in total via the central CPU, all input for call up is from locations around the complex via a hot key selection to call up a menu to select the information to be sent to whatever destination is desired.  In addition the output is also being streamed via a web server to the total intranet service for display on all PC's.
Long term intent is to add Teletext input to the system ( this part is being explored by the end user).
Chuck
Gene Sudduth/CHYRON
12/05/2005 01:52 PM
To
   Charles Motta/CHYRON@CHYRON
cc
Subject
Chuck,
Who can help me with this?
Thanks,
Gene
----- Forwarded by Gene Sudduth/CHYRON on 12/05/2005 12:47 PM -----
briantennyson <briant@adgkc.com>
12/05/2005 11:55 AM
To
   gsudduth@chyron.com
cc
Subject
Gene,
Recently on a thread I moderate a question has arisen about how the /Two
Channel ChyAlert Video Emergency and Security Alert System is deployed.
If you could look at the thread and answer on line or e-mail me a
response that I can post it would be greatly appreciated.
/http://srforums.prosoundweb.com/index.php/t/10127/11606/?SQ =dc0a682a546a60a91c0e7f34b97c5bb0
Brian Tennyson
Acoustical Design Group
Looks like you could do it either way depending on how many tv you have as opposed to how many channels you want it on.
10 TV's with 110 channels, deploy it on the TV's.
100 TV's with 25 channels, deploy it on the channels.
Visitec
www.visitec.com
Ken Freeman
« Reply #7 on: December 07, 2005, 02:00:48 am »
Hotel A/V at its finest!
Ken
Page created in 0.051 seconds with 19 queries.
