Author Topic: Do you have a favorite plate amp?  (Read 1798 times)
(Brian) Frost
« on: September 28, 2005, 06:02:09 pm »
I have some passive martin subs that I would like to make active.  Does anyone have a favorite 500w  mono plate amp that I can install into these subs.  Ideally it would have XLR inputs as well as low pass.
Thanks
Frost
Frost
Owner, Narnia Productions
www.NarniaProductions.com
Chicago IL
Good is good but not as good as better
Simon Coffin
Speakerpower
« Reply #1 on: September 29, 2005, 05:20:39 am »
Take a look at www.SpeakerPower.net.
I have just ordered two of them for a coax wedge project.  Can't say anything about the build or sound quality yet, but the specs look good.  They use a programable DSP that you could use for low and high pass filters, any eq required and limiting.
ciao
Simon
Re: Speakerpower
« Reply #2 on: September 29, 2005, 07:05:21 am »
Simon Coffin wrote on Thu, 29 September 2005 05:20
ciao
Simon
I have only used a couple of them.  They do meet rated spec with continous sine wave input-not burst power spec as some other manufacturers.
The DSP is VERY different than any other in existance (that I know of)  You can do whatever you want, BUT you have to stand on your head-scratch the bottom of your foot-stick your tounge out and recite the alphabet backwards to get around on it.  It is not intuitive at all.  But that keeps the riff raff out of it.  It is also not real time which is a pain.
I have been happy so far.  They have mono-2 and 3 channel units.
The output are already bridged-so you have to be careful with the wiring and don't let any outputs touch each other or the chassis.  XLR in and out and powercon in and out also for daisychaining.  There are 2 programs available on the DSP units with a switch.
dB Audio & Video Inc.
Page created in 0.028 seconds with 20 queries.
