Hi Tom (whoa - great pix!), Iain, Phil , guys (hey Ivan - U find half-clam sketch?)
re: distance and plots here's an 8cu.ft K-box about like K15 but missing shelf refinements and loaded with a 0.25qts / 103g mms Eminence 18 vs UCS1 at 44ft distance. had K tuned ~42Hz z-minimum with two 4"ID x 4.5" long vents on its 1st reflector panel. each cabinet was in same spot against corner of house and mic not moved:
http://home.earthlink.net/~buddhaboy2/44F.jpg 34Hz low level sine K vs UCS1 - 15dB more H3 on the pipehorn:
http://home.earthlink.net/~buddhaboy2/34hz.jpg30vrms 50hz for K-box - careful not to smoke that coil!
http://home.earthlink.net/~buddhaboy2/30vrms.jpgRough side-view sketch of that 8cu.ft. k-coupler - its vents are 4.5"
holes on the 1st reflector panel. one board and an upper piece would probably be as good for midbass work. It started as a 15" coupler but got bored and took jigsaw to it to see what it would do with 18"
http://home.earthlink.net/~buddhaboy2/8cu.jpgAnother arrangement within 7.4cu.ft. which might work could be like so
(woofer is same Eminence 18" used in 8cu.ft. coupler above)
http://img358.imageshack.us/img358/4287/ha18capwjpg1co.jpgThis mod with extra cavity and a handful of polyfill produced the following 2M plots (rear chamber volume ~80l)
http://img408.imageshack.us/img408/7889/2mwebjpg4rx.jpgwhether sine testing showing high H3 has significant meaning vs "tone" - dunno
wideband, the original 1951-52 Karlson is probably tighter on than my box above - (15 vs 18 plus lowpass choke)
I'd normally tune this k a bit higher for a riper upper bass and nice shockwave effect. also like it as took one sheet of cheap plywood and weighs about 70lb loaded vs nearly double for the Unity.
The UCS1 had lots more 3rd harmonic than this k-box below 50. UCS1 also has a higher Z-in - think around 10 ohms minimum- -neither are any good in my house for 32Hz -haha
John Karlson musta had good relations with Robert Moses as K15 (probably with EV 15RTX) was used in several exhibits at the 1964-65 World's Fair including Ford (with Disney Animatronics) GE and other exhibits. a reliable source says Karlson did a rocket mic-speaker install for Moses and in abtract way reflected the twin-towers project.
FWIW in the legend of Karlson its said that loading below cutoff is one feature:
snippet from Dave Young's post:
I have built and used various Karlson couplers for PA since 1983.
There have been 15" and 18" woofers in 2'x2'x3' Karlsons of my own design.
"-For a while, I used X-15's for midrange with very
drastic equalization. I have used the Tube on top of a 12" Altec
for small jobs. I have also made a 2" Tube coupled to a Renkus-
Heinz 3300-8 for outdoor use. There are also some 12" coaxials in
use with a K-coupler for the highs.
As a low frequency cabinet, the Karlson is usable to 35hz with
low harmonic distortion.
Like any enclosure that depends on porting to augment the bass output, Theile-Small parameters have to be taken into consideration. I have yet to measure anything of comparitive size
that came close.
They get ugly above 175 hz. and require a crossover set from 100-150 hz.
The key to its low freq. performance is the coupled front chamber.
The increased air pressure loads the cone and dampens it.
A front loaded woofer and a horn loaded woofer operating below cutoff doesn't have that
advantage.
Twice I've measured the 3rd harmonic of 40hz(120 hz) louder than the fundamental with 100 watts
feeding the speaker.
The Peavey FH-1 and a Yorkville 2-18 with RCF's. When the 1504-4
Black Widow was tested in a 12 cu. ft. Karlson, the 3rd harmonic
distortion went from 103% to 8%. I didn't have the Yorkville long
enough to switch speakers."
Carl says mass loading changes T-S parameters and evaluates up to 5 sets of wings (whew) - by his critera a Karlson bass coupler would not have a large rear chamber.
if feel up to it - do some plots of Transylvania Tube in 15 degree increments at several heights.
re:K-Tubes - x15's tube imo has a significant ammount of energy propogated perpendicular to its long axis so theres a fairly high and even vertical window.
Too Tall mentioned the Transylvania tube (which normally has slot "down" and tube angled up ~30 degrees) not having high vertical dipsersion - not sure - up close didn't seem to have much anything happening right above its structure- maybe it can be aimed towards the rear of an audience to good effect - straight down the tube would be imo where the highest HF goes (from listening to tape-hiss components)
Here's an indoors plot of a x15 copy with mic going up to overhead and perpendicular to the waveguide (loaded IIRC w. old PV 22A) the 1.875"ID tube on this Karlson x15 is mounted on its first reflector panel and aimed down 12 degrees from being parallel with the floor. (12 degrees subtracted from a nominal 35 degrees give the 23 degree baffle tilt)
http://home.earthlink.net/~buddhaboy2/X15/Perp.jpgHere's same coupler/tube 85 to almost 90 degrees off horizontal axis in-room - that's the mic's position - lol
http://home.earthlink.net/~buddhaboy2/X15/Horz.jpglike to get rid of that 2K2 notch - maybe wasn't as deep with 806a(?) was it from a diameter transition of a 1" OD 30 degree slice pre-waveguide to 1.875" ID tube?
Karlson presented two circuit models for the coupler in 1952 Audio Engineering article - separate circuit for LF.
what type of Z tranformer (if any) is an Ultra-Fidelity type Karlson? - some couplers seem to have high outputs with good cone control. there could be BP action - but is there more?
maybe they're 100% bunk - but can/or seem do some "stuff"/ give illusion - I like the vortex gun type effect on kickdrums
Best wishes to all
Freddy
ps - one more thing - here's plans for 18" 5181 10.3 cubic feet Karlson cabinet by Cetec-Gauss. note - dimensions on page one include carpet. look at page 3 before building - lol (also double check that wing radius to see if correct)
http://home.earthlink.net/~buddhaboy2/GKcan some K-couplers be made to work stronger within their passband for a given bulk by allocating more air-mass load from front chamber so rear chamber isn't quite as large as 5181's approach? - thoughts?
