Author Topic: Punisher Sub  (Read 12119 times)
[x]
Re: Punisher Sub
« Reply #10 on: October 15, 2005, 10:16:26 am »
In theory. But not all drivers will work on all horns, and you would need to find a driver that would model well in McBean's Hornresp.
I've said and written things in the past that I wouldn't throw away in my own trash can for fear that you'd find them. My name is mud.
Mircea Bartic
    • http://www.poweraudio.ro
Re: Punisher Sub
« Reply #11 on: November 28, 2005, 09:39:07 am »
About the punsiher loaded with P-audio SD-12 version.
I have made simulations using this driver instead of the Ciare, and it seems that it will work at least the same as the ciare one
I have ordered 4 pieces from the manufacturer as the sd-series are not imported here in Romania on a regular basis.
In a few weeks I will have the first prototype built and I will see  what it will perform like.
I have high espectations based on the simulations
Be advised that this could take a while because the speakers have to be delivered to me from thailand with the importer's next shipment
I'll keep you posted
140dB @ 40 Hz
Mircea Bartic
Re: Punisher Sub
« Reply #12 on: November 28, 2005, 12:16:10 pm »
below there is a simulation of the Ciare 12.00Sw Vs the P-audio SD-12
the grey line is the P-audio and the Black one is the ciare
http://www.stocare.as.ro/sd12.gif
simulation is made with one subwoofer in a corner (0.5 pi) with 1W of imput.
140dB @ 40 Hz
[x]
Re: Punisher Sub
« Reply #13 on: November 28, 2005, 02:22:22 pm »
Which means you'll need to stack four to get a similarly flat response.
Mircea Bartic
Re: Punisher Sub
« Reply #14 on: November 28, 2005, 03:03:19 pm »
yes, the horn resp points to four pieces/side for flat response, but they were used by the original designer 2 per side with good succes.
Even in 1Pi, there is not such a big problem, the plot still stays reasonably flat.
if you look closely , it apears that the sd wil go flatter than the ciare speaker
140dB @ 40 Hz
Peter Morris
Re: Punisher Sub
« Reply #15 on: November 28, 2005, 08:22:06 pm »
Page created in 0.052 seconds with 19 queries.
