Author Topic: Punisher Sub  (Read 12134 times)
goblacks
Punisher Sub
« on: September 01, 2005, 03:20:37 pm »
Hallo Everybody,
I am based in New Zealand and have been looking into building a couple of punisher horns.  Unfortunately I haven't been able to find Ciare distributors here. Would anybody have an idea as to where I might be able to find the woofers in New Zealand or where I can get them couriered cheaply.
Thanks!
Michael_Elliston¶
    • http://www.geocities.com/xobt
Re: Punisher Sub
« Reply #1 on: September 01, 2005, 09:31:44 pm »
hey.
I too live in NZ with its HUGELY limited driver selection,so I feel your pain. For me it was either an adire audio SHIVA, or a 2nd hand jbl2226. I got the 2226,and love it.
Im SURE I saw an australian distributor of CIARE,but the sites dont seen to appear in search engines easily. Email ciare,asking for a local distributor. Try yahoo.com.au,search within OZ.
I know you can get EMINENCE here from auckland,but if your buying a couple its probably still cheaper to import from partsexpress.com ! The lab12 is similar but Fs is quite different otherwise id use it on the punisher.
Bear in mind that there are alternatives.
goblacks
Re: Punisher Sub
« Reply #2 on: September 04, 2005, 07:27:30 am »
Hey Mike,
Thank you for the info. I did do a search for Ciare in Australia but couldn't find anything useful though.  If you have any contact info in the future I'd appreciate it very much.
Yes Audio stuff is quite expensive down here, I envy the guys in the states sometimes Smile
One brand that I can get super cheap in New Zealand though is P Audio, there are some guys that ship them directly from the factory. I was wondering if somehing like the SD range of woofers might work in the punisher cab?
Thanks!
Michael_Elliston¶
Re: Punisher Sub
« Reply #3 on: September 04, 2005, 11:25:14 pm »
goblacks wrote on Sun, 04 September 2005 23:27
Hey Mike,
Thanks!
No doubt,there will be a woofer similar that will do mostly the same thing on the punisher horn-but whether it is as good response is the issue.
I could model up something on the punisher,or a similar horn.
The SD12 has about 1/3 - half the Xmax of the Ciare12
While the xmax on the punisher is high,the Xmech is only as high as typical PA drivers.
Which is good in a way,because then you can get the typical distortion at highest SPL,to warn you of destruction of drivers,while providing people with high distortion levels if they wish Razz
You could try and 'cheat' by using car audio 12"s for CHEEP from parallelimported.co.nz, could have some use.
Can I ask : How many punishers were you going to build?
Indoor usage?
What sort of music?
Fixed or portable?
raj
    • http://-
Re: Punisher Sub
« Reply #4 on: September 13, 2005, 02:12:09 pm »
P- Audio model SD15 seems promising , You could try the design for that at speakerplans
RL
Jack Arnott
    • http://assistanceaudio.com
Re: Punisher Sub
« Reply #5 on: September 16, 2005, 09:28:08 am »
Howdy,
First off its CIARE! (Pronounced Chee-are-aye)
You wouldn't write Jbl, Bms, B&c, Eaw, etc.
I show that there is a distributor in Indonesia. Does that help?
If not I can ship them USPS surface from the US.
Contact me if I can help.
Regards, Jack Arnott
The Buffalo's already dead,
What was going through your head?
Why did you choose the color Re-ed?
Joss Whedon
www.assistanceaudio.com
raj
    • http://-
Re: Punisher Sub
« Reply #6 on: September 17, 2005, 07:56:44 pm »
If walt or someone else  modifies  the The Punisher Cabs for 15" drivers , the driver problem for may be sorted out , as 15" woofers are more easily availible everywhere .
RL
Michael_Elliston¶
Re: Punisher Sub
« Reply #7 on: September 18, 2005, 11:49:09 pm »
raj wrote on Sun, 18 September 2005 11:56
It wouldnt be a punisher then.
I have no problem with a larger horn,closer to 400litre eg WSX size.
The high power,high linear excursion driver is part of the tiny horn trick.
50hz is enough for most people anyway !
raj
    • http://-
Re: Punisher Sub
« Reply #8 on: September 19, 2005, 12:51:24 pm »
You are right Mike , only said that because many are finding difficulty in getting the Driver .
RL
Gaston Oberti
Re: Punisher Sub
« Reply #9 on: October 14, 2005, 09:05:10 am »
Some time ago i asked what if we scale down a horn to fit an 8'' driver.. the answer.. no way! the path and horn mouth are reduced increasing cutoff freq..
so logically, if we scale up the horn, the punisher, lets say.. we will go lower
Gaston Oberti
MSN: notsag20@hotmail.com
Even a broken watch sets exact time twice a day
Page created in 0.041 seconds with 20 queries.
