Author Topic: Typical transient response  (Read 4019 times)
Gareth James
« on: August 16, 2005, 01:33:01 pm »
Can anyone tell me any real figures for a typical transient response (not sure if my wording is right here) or the time for the emitted sound from a basshorn or other bass speaker to decay by for instance 6 or 10dB after receiving a given impulse.
I realise this is quite a complex question to answer properly but if anyone has any general ideas they would be greatly appreciated! Razz
Brad Litz
Re: Typical transient response
« Reply #1 on: August 20, 2005, 06:33:45 pm »
Here is a measurement I took of two LABsub cabinets.
index.php/fa/2312/0/
Brad Litz
Michael 'Bink' Knowles
    • http://www.binkster.net/index.shtml
« Reply #2 on: August 20, 2005, 06:44:51 pm »
Brad Litz wrote on Sat, 20 August 2005 15:33
That's really cool, Brad. I've never seen a graph like that -- I don't do impulse testing in my live sound work.
Can you explain what it is we are looking at? For instance, why are there little low-SPL hillocks near 30, 40 and 50 Hz that are stretched out in time? Do those hillocks show a leading sound or a trailing sound? Where is time = zero? Close to the viewer or far from the viewer at the dB plane?
-Bink
www.binkster.net
Brad Litz
Cumulative Spectral Decay Plot
« Reply #3 on: August 20, 2005, 07:48:28 pm »
The chart is a cumulative spectral decay plot, commonly called a waterfall plot. Time zero is at the "back wall" where the level is the highest. The "low-SPL hillocks" you mentioned are indicating that there is some reduced contribution to the response at those frequencies for a longer period of time.
I took the measurement outdoors as you can see in the photo. Perhaps the rather flimsy garage door baffle contributed some sound of its own.
index.php/fa/2313/0/
Here is a link with some explanation.
http://www.libinst.com/wattlar.htm
Brad Litz
Gareth James
« Reply #4 on: August 21, 2005, 07:18:32 am »
Wow, thanks brad thats exactly the kind of info i was looking for...
So if im reading this right, thats about 40ms average decay time below 100hz, with peaks up to 100ms or more at the resonant frequencies of horn (and drivers?)
I think you're right, maybe one of those peaks is your garage doors... Confused  Confused
still some awesome data.... i assume a vented box would have a greater average decay time, maybe approaching double the 40ms figure...
Too Tall (Curtis H. List)
Re: Cumulative Spectral Decay Plot
« Reply #5 on: August 21, 2005, 05:56:04 pm »
Hey Brad, clever setup.
All I have is a fiberglass door, though it might work after all.
Here is a Praxis waterfall taken from an Impulse Response of a single LAB sub outdoors. This is a version 1 design.
I believe the mic is near field at the mouth of the horn.
The plot is 100ms deep with each line 2ms.
Freq range from 20Hz to 100Hz.
My next post shows the same sub taken at 20feet (about 6 meters).
Too Tall
        Curtis H. List
             Bridgeport, Mich.
        I.A.T.S.E. Local # 274 (Gold Card)
        Lansing, Mich
Independent Live Sound Engineer (and I'm Tall Too!)
« Reply #6 on: August 21, 2005, 05:57:52 pm »
This shows the same sub taken at 20feet (about 6 meters).
Too Tall
        Curtis H. List
             Bridgeport, Mich.
        Lansing, Mich
« Reply #7 on: August 21, 2005, 06:46:38 pm »
[quote title=Bink wrote on Sat, 20 August 2005 18:44]
-Bink
BTW Bink, if you want to do Waterfalls (called CSD in Praxis, Cumulative Spectral Decay) or do FFT with gates, ETC, Group delay, add/subtract time files, multiply/divide freq. response and about a dozen other things all you need to do is start saving your IR from Smaart as ASCII files and import them into the Praxis demo.
If you have any questions about settings let me know.
Too Tall
        Curtis H. List
             Bridgeport, Mich.
        Lansing, Mich
Brad Litz
« Reply #8 on: August 21, 2005, 07:15:29 pm »
Too Tall wrote on Sun, 21 August 2005 16:56
I think the the fiberglass door may be better than the sheet metal one I have. The roll up design of mine keeps the panel size small and fairly stiff.
Since the LABsub horn design is intended for a group of four on an open ground plane, two "in the garage door" should be close to the same.
Brad Litz
Peter Morris
« Reply #9 on: August 21, 2005, 08:01:07 pm »
The LAB horn is about 10 feet long, so the resonance associated with its length will be at about 30Hz.  Thats what you are seeing, resonance, the cone or anything else for that matter including the box, keeps vibrating after the signal has stopped.  What you see as time goes on (the Z axis in this case) is an ever decreasing amount of energy, mainly at 30 Hz and some at 60Hz, which is exactly what you would expect in this case.  There is some at 40, this maybe the box, the wall, don’t know.
As you put more of the LABs in a stack and the mouth becomes bigger it will begin to behave more like a horn and not a resonant length of pipe at these low frequencies.
Having said that – that’s a very good plot in any case, but they are loaded in 1 / 4 space.
Peter
Page created in 0.039 seconds with 18 queries.
