Woody wrote on Wed, 15 June 2005 22:23 |
I started out in concert sound, and to be honest, we didn't worry about amplifier levels that much. We turned them up to "11" and off we went. Some nights my console was barely bumping the meters and other nights they were pegging. I wasn't all that concerned as long as I had enough headroom. I've also done numerous installs for auditoriums, but my designs were based primarily on my experience and the experience of the house guy I was installing for. I know it's not all that scientific, but when you work alot of shows on a wide variety of rigs, you have a pretty good idea of what works and what doesn't.
This barely qualifies in todays market with good firms. Any of the firms that I would hire do extensive computer modeling of the space, have a well defined performance spec, and perform detailed measurements to show the client they meet this spec. The also provide a complete set of CAD drawings for every little nook and cranny of the system.
Quote: |
Lately however, I'm bidding alot of school and church auditoriums and the like, with very specific requirements, and designing rooms for users who are very green. So what I'm asking is a discussion on initial system set ups. My design principles are solid but on the initial set up, I'd like to hear how everyone goes through it. I assume that everyone does it a little different.
For example: -Are you running broadband noise through your console at 0dB to hit a target SPL and then balancing from there?
Consultants typically design systems backwards, starting with SPL goals on the audience area, and then tailoring the speaker systems and amplifiers to match. This may mean undersized speakers and/or amplifiers relative to a concert rig. Any "excess" reduces the chances of being the financially competitive bid. Now, as a practical matter, many install systems in churches and performance spaces are spec'ed as stoutly as a concert rig these days.
As for your console gain structure, everything needs to clip at the same time. This maximizes the systems signal to noise ratio, an important consideration in quiet boardroom-type environments.
A practical example:
Your spec says the system will do 110dbC from 40hz-15khz and be within +/- 2dB across the seating area from 150hz to 12khz, using a pink noise source with a crest factor of 6dB.
Your FOH console clips at +22dB, and your DSP analog front end clips at +20. This means that, with your stimulus, the system must be running 110dBA with the console output at +16dB, and the clip lights just tickling on peaks. It also means that you need 2dB of input attenuation for your DSP. While most people don't cut the margins quite this close, there are rigid mathematics to set all these requirements.
Quote: |
-If the above is your procedure, what is your typical SPL target for different room varieties? School Auditoriums, churches, performance halls, etc.
That has a lot to do with the venue content. I work with one church where a system that does 105-110dB
A gives them the headroom to cover all their events. They don't normally run that loud, but some of the acts they have into their room do.
Quote: |
-How much variance in level and/or frequency response are you finding acceptable?
A good firm should easily be able to do +/-3dB across all the seating area above the Schroeder frequency up to at least 12k. And they need to have the tools to properly verify this.
Quote: |
-How much headroom are you factoring in on the design process? If I don't use enough, aren't I at risk of having my mic pre's cranked too wide open?
Well, lets start by defining what you think of headroom. Headroom is a ratio of the peak to average levels in a system, a dimensionless parameter. If the average level is 92dB, and the peak 107, the system needs 15dB of headroom. A peak to average ratio of 15dB is a decent starting guideline in my book.
I'm not really sure what the preamp gain levels have to do with this, but this post is not about the subtleties of console gain structure.
Quote: |
-What types of tests from Smaart, TEF or otherwise, are you finding the most beneficial in DSP balancing, EQ and delay settings?
NONE if they aren't measured properly!! I would expect delay zones set by smaart, and properly measured transfer functions of the as tuned system, possibly including some ground plane measurements.
Quote: |
If anyone can think of any other considerations that I'm missing here, by all means add them to the discussion.
Don't take this the wrong way, but I don't feel like you have a good grasp on the fundamentals that many consultant types will take for granted. You might want to take a Syn Aud Con class, buy a copy of sound system engineering, and learn some of the fairly easy math behind a more formal system design process.
