Hi Walt,
I hadn't seen that box, and it took a little digging to find info on it as it has been discontinued without a comparable replacement - maybe wasn't up to par?
A few things I have noticed with it. The dispersion narrows significantly below the crossover point, which tends to increase the level on axis. They utilised high sensitivity drivers with a rising response and small Xmax. Even though the driver can reach 104db sensitivity, two of them in this box can only manage 108, which indicates there is very little horn loading going on at the top end. From the photos, drawings and impedance chart, it looks like they used a short 200Hz horn and assisted it with reflex loading around 160Hz. Their own controller crosses the box at 125Hz, I would suspect due to running out of excursion.
As I mentioned before, it is about tradeoffs, and in this case the tradeoffs may have sealed its fate, and this box certainly wouldn't be much use with a LabSub. I think your choice to go with the 8" midrange is more appropriate.
Cheers
Graeme
