Ivan Beaver wrote on Fri, 29 April 2005 19:33 |
Actually it can, BUT the power will drop to 600 watts @4 ohm bridged. It is rated for 300 watt/channel @ 2 ohms. Also the damping will be halved (due to bridging). I would not recommend it, even though you can do it safely. That old model is the one that you can drive into a shorted load with no problem (see my earlier post). The power delivered to the load just keeps going down.
Sure you can hook it up that way but it will current limit because it was designed for
4 ohms min. I have heard of some folks going back in and changing the current limit values because it was conservatively designed, but it was designed for 4 ohms min... Trust me, I didn't design it but I know Jack....... Sondermeyer (the designer) and he didn't have 2 ohms on his radar screen in those days.
Regarding driving a short circuit, any modern amplifier that's worth it's salt should heat up your screwdriver, or shorting implement of choice, before hurting itself. This is a routine QA test during production, because customers short outputs all the time and despite the "justice" in releasing smoke they would only deny that they did it and blame the manufacturer, so shorting the output is no big deal.
Some of the new kids on the block may not have this "detail" figured out, and I recall one home brew A-B test box that would inadvertently short the amps during switching that managed to blow up more than one competitor's amp, but I repeat... AFAIK this is or should be pretty standard for all amps. Short the output and it will get hot, then shut down. (Boys and girls... this isn't license to go do that... only you should be able to tolerate such mistakes when they happen without catastrophe.)
PS.. FWIW I've heard sundry anecdotal reports of mistakenly running CS amps into 1 ohm loads and not realizing until after the show... Of course I don't advise ever running below the rated impedance.
