Timmahh wrote on Sat, 02 April 2005 12:03 |
snip-
I have Smaart on my laptop, but not sure if my mic input is stereo or not, dont think it is but. so my question here is what are you peeps useing to go from xlr for the RTA mic, to your laptops. i ve looked at the m audio and the VX pcmcia card, but was wondering if there is anything else out there i should consider using befor making my final purchase. the Digigram VX card looks pretty nice. i also see creative labs have made a pcmcia soundblaster card with a spdif and rca connections, anyone use this, it s price range is good at 130.00 or 80 for the usb breakout style box with a few extra connections.
Snip-
Your on board sound chip needs to pass several tests.
First you need a stereo input.
If your laptop only has a "mic" input you need that to be true stereo. If it also has a "line" input you can ignore the mic input. It is unlikely you will use a mic that would work properly into it and many laptop mic preamps are garbage.
To tests for true stereo for either the mic or line input all you have to do is record a wav file and make sure you are only feeding one channel. Then play it back and see if the sound shows up on one or both channels or only the one you had the microphone hooked up to. Do the test for all inputs.
Next you need to be able to shut off any monitor signal at the output since this will cause a feedback loop.
To do this feed a signal into the input and record it to a wav file and while you are recording listen to the output. There should be nothing there. If there is you need to go into the windows mixer and choose "playback" under properties, then look for something that can shut off the monitor signal to the output. The wav output still has to stay on and turned up. If there is a master volume out that has to stay turned up. Everything else needs to be muted or turned down all the way.
Is your on board sound chip good enough for what you are doing?
If you bring it down to Bridgeport I can hook up a ESI U24 usb soundcard and compare it to the on board chip. I did that with the chip on my Thinkpad and it was very close to both my U24 and my Echo Gina pro card in my desktop tower. If drops off on the low end and I believe it has little more noise overall. For EQing a PA I would not hesitate to use it.
That said you can buy usb sound cards for cheap. I stay with usb soundcards because I don't like to tie up the pcmcia input. You can stack lots of usb on a hub.
In any case odds are you will have to use an external because the chip will not be Stereo full duplex.
You need to look at the mic you will buy, the mic preamp it needs and the external (or internal if you use it) soundcard all at the same time.
If you only spend $30.00 on a Behringer ECM8000 measurement mic it is foolish to spend the money for an expensive USBpre soundcard. You could buy a cheap USB card (if you need it) and a stand alone mic preamp for just over $100.
I'm including a zip file showing the comparison test I did comparing my Echo Gina 2x8 PCI sound card with the crystal fusion chip in my laptop and a iMIC that works with both Macintosh and PC (It is VERY cheap).
