thesuperspike wrote on Thu, 17 March 2005 21:10 |
I would say the TC m300 is not up to par with the Lexicon MPX1 It has decent effects but is not totally user selectable.(by this I mean the fine tuning/no display) I wouldn't even say the mpx550 is, although it does sound nice. I would personally go with a TC m2000, sells now for a little less the the MPX1 did new. I own three of these so I am a little biased, but I used to have a MPX1 and enjoy the TC more. The one thing I like best about the TC is that you can run 2 auxes in to 2 seperate effects and run stereo out. If you are looking for another machine that still sounds good but is cheaper, I would go with the TC m-oneXL. All in all you can go wrong with most new effect units in the $350 - $750 range.
[Edit] - Grammar
The M300 has sound similar to the MPX1, as a matter of fact, some of the reverbs on the M300 are better then MPX1 presets to my ear.
As far as fine tuning, the unit provides analog knobs that will allow a more visual representation of settings. All the values that you need to menu to are there on the knobs.
Tap delay, decent specs, SPDIF out.
It has memory presets to store any patch you can twiddle up.
It also is dual channel. You can use 1 aux for reverb, one for multiFX, and they both come back to the same stereo return.
It can also be used as a stereo AD coverter, just send stereo to the inputs, and tap off the SPDIF output to digital.
It's just about the best damn $200 processor out there.
Yup, the m-one is a better unit at more money, and is more digital friendly if you're into that kind of thing.
I'd recommend the Fireworx too, if I think the guy had the bucks.
I've got a 550 in the same rack with the M300. I like the 550 a lot, but I wouldn't get rid of the M300 for anything.
