Author Topic: Mini LAB (hifi) (building right now; pics inside)  (Read 11480 times)
Michael_Elliston¶
    • http://www.geocities.com/xobt
Re: Mini LAB (hifi)
« Reply #10 on: December 15, 2004, 10:37:20 pm »
If you had stereo subwoofers which reached up to 120hz that will minimise the horn size of the 120hz+ unit
A horn is another new sound compared to yuck bandpass,Ive never bothered building one,I know their bad. Instead I have a jbl 15" on overdamped bass reflex in my lounge Smile
michiel
Re: Mini LAB (hifi)
« Reply #11 on: December 16, 2004, 04:21:36 am »
I didn't say bandpass, but bandpas horn. Here is a drawing: http://www.speakerstore.nl/constructions/pbaudio/bandpasshoo rn_18/bandpass_18_1.gif Mine is modifed for 15" drivers.
The same as the F1, turbo and mach ballister subs. It isnt a horn, it isnt a bandpass, just a realy good mix of both witch sounds great! The only thing i'm worried about is the higher part of the band with, say about 250-350 Hz.
A straight horn will always preform better in my opinion. Maybe im going to test this in the comming year.
Roy N.
Re: Mini LAB (hifi)
« Reply #12 on: December 17, 2004, 07:55:10 am »
Hi Michiel,
How are you? That bandpass horn you have in speakerstore I am building right now with PD1850 what was the useable frequency response from your driver that you originally used? Also with the PD1850 what would be the HPF set at? What is the predicted response with the PD1850? I modified the cabinet a little using two horns in one cab and a support in the first bend and using 18mm Baltic Birch like what Bernie Sauderland did. Thanks!
michiel
Re: Mini LAB (hifi)
« Reply #13 on: December 19, 2004, 02:03:49 pm »
Roy, did you get my
PM??
michiel
Re: Mini LAB (hifi)
« Reply #14 on: December 27, 2004, 12:37:03 pm »
I started building this horn a few days a go. I'm building the double 8" version wich is indentical to the LAB12 loaded version except foor the baffle cut outs.
Some pics:
http://images2.fotopic.net/?iid=ys2vyu&outx=600&nore size=1&nostamp=1
http://images4.fotopic.net/?iid=ys2vtf&outx=600&nore size=1&nostamp=1
http://images2.fotopic.net/?iid=ys3chk&outx=600&nore size=1&nostamp=1
http://images3.fotopic.net/?iid=ys3dv8&outx=600&nore size=1&nostamp=1
http://images4.fotopic.net/?iid=ys2vyr&outx=600&nore size=1&nostamp=1
[x]
Re: Mini LAB (hifi) (building right now; pics inside)
« Reply #15 on: January 12, 2005, 01:50:25 pm »
How does that horn model up with a Peavey Low Rider 15?
I've said and written things in the past that I wouldn't throw away in my own trash can for fear that you'd find them. My name is mud.
michiel
« Reply #16 on: January 23, 2005, 01:43:54 pm »
Almost ready. Smile Next weekend i'n planning to do the first tests.
For pics see: http://michiel-rijckaert.fotopic.net/c379291_1.html
What are the T/S of the peavy? I dont know if a 15" will go well in this horn since I designed the horn  for the LAB 12.
But, maybe it will work.
Page created in 0.058 seconds with 20 queries.
