Quote: |
One enclosure has a +/-3dB response of 55-330 Hz, with a slight +3dB rise near 200 Hz
Most basshorns out there have a pretty good response up to at least 200 Hz. The only problem is that most basshorns also don't sound to well above, let's say 120 Hz.
And that's the biggest problem with simulating as well. Hornresp might give you a pretty good idea what kinda things you can and can't expect, in terms of response, SPL, cone excursion, etc.. But it won't tell you much about "the sound" the cab has. Or some hidden surprises you might encounter. The program will let you get away with a compression factor of 5:1, the speaker might not.
I have (and will) build most of my own designs as prototypes, some get several versions, all at least get tweaked. Some did better then I expected, some worse. One cab had a very nice simulated response, a very disappointing response measurement, but a great sound. The simulation couldn't tell me, the measurement sure didn't. The prototype did.
Truth is that every person on this forum can use Horn resp well enough in a month orso to design a pretty good theoretical horn.
But a horn designed by a sound engineer can turn out to be a complete joke. While a dummy could hit the jackpot.
Mvg Johan
