Pages: [1] 2 3   Go Down
Author Topic: Crusher 3D drawings  (Read 10485 times)
Walt de Jong
Crusher 3D drawings
« on: December 09, 2004, 11:13:03 am »
Some 3D pictures of the Crusher:
Walt de Jong
Re: Crusher 3D drawings
« Reply #1 on: December 09, 2004, 11:13:37 am »
Walt de Jong
« Reply #2 on: December 09, 2004, 11:14:04 am »
[x]
« Reply #3 on: December 09, 2004, 11:14:13 am »
[x]
I've said and written things in the past that I wouldn't throw away in my own trash can for fear that you'd find them. My name is mud.
Walt de Jong
« Reply #4 on: December 09, 2004, 11:22:00 am »
Walt de Jong
« Reply #5 on: December 09, 2004, 11:25:16 am »
Walt de Jong
« Reply #6 on: December 09, 2004, 11:33:44 am »
You mean something like this?
I will do the 3D drawings again if you have the final drawings, it is not that much work.
Best regards,
Walt
Elliot Thompson
« Reply #7 on: December 09, 2004, 11:39:06 am »
Hey Walt.
The pressure build up between the woofer, and,
the baffle board, must be enormous.
What is the BL Factor, of the driver, and,
what cone material does it use?
I'm assuming Kevlar........
Best Regards,
Elliot
Walt de Jong
« Reply #8 on: December 09, 2004, 11:43:07 am »
I only did the 3D renderings! The Crusher is not my design.  Driver is Eminence HL10A, you can find specs on the Eminence homepage...
Best regards,
Walt
Walt de Jong
Corners
« Reply #9 on: December 09, 2004, 11:50:10 am »
Hello BHF,
I noticed that in the corners the area doesn't expand in your Crusher design. 5" stays 5" and 10" stays 10". In fact the area should be larger at the end of the corner because in the corner the horn should follow the expansion rate. Look at the Punisher plans to see what I mean.
Best regards,
Walt
Pages: [1] 2 3   Go Up
Page created in 0.055 seconds with 19 queries.
