The Crusher is a fairly efficient horn, and really about as efficient as the Punisher. The enclosure is not as wide as a Punisher's enclosure, by about 4 inches. It is about 3 inches taller. How do I justify the extra size? I wanted to make this horn good to 40 Hz, and you just don't get that without a big mouth. This horn is geared towards providing LF extension, whereas the Punisher might have a "punchier" sound good for dance music. Another thing the Punisher has going for it here is its very high power handling. I should email Eminence and see how their RMS power ratings compare to the AES rating that the Ciare driver states. I wanted to focus on LF extension because I want to get that lowest note on a bass guitar, and I know that extension can be an elusive goal in a small horn. However, I use the entire front panel for mouth area, so it's not like it's wasted space. My horn is 4" wider than John Sheerin's HL10 horn. John was invaluable in his assistance to this project.
I did, however, make an interesting discovery relating to the horn's lowest usable frequency. I had been using old numbers for my path lengths. New numbers are a fair bit longer, and the result is that you can get 43 Hz (usable, -5dB) from just TWO horns. Four horns get flat (-0dB) response to 45 Hz and have usable response to 39 Hz (usable, -5dB)! But it's not surprising when you have over nine feet of horn in the enclosure! This surpassed my own expectations.
I'll probably ask for a simple CAD program for Christmas, so I can produce some more accurate detail prints, so for those of you who aren't in a hurry, just wait on that. They should be ready by the end of January if I get this program.
So, Walt, to answer your questions, it doesn't go much louder, but it goes deeper by a small amount. And to prove I'm not blowing smoke here, here's a new Hornresp plot for four boxes, ground stacked. Yay for deep horn bass. It's no LABHorn, but it should be able to do what most people want it to do. And if you want the really low stuff and are willing to deal with a huge box, then go ahead and build a LAB.
To power the thing, the Crown Xs900 should be a good match for four boxes. Each channel powers two boxes. Power handling of the HL10 driver is 300w RMS.
