Author Topic: USB to Serial Adapters  (Read 99809 times)
Charles Johnson
« on: December 03, 2004, 02:32:02 pm »
Greetings all,
I'm upgrading to a new laptop that does not have a serial port on it and am looking for a good USB-to-Serial-Port adapter. Since my main use for it will be to interface with Ashly digital products, I gave Ashly a call to see what they recommended. They (well, to be specific, Mike in the Tech Support Dept) recommended the GUC232A from IOGear. My concern, though, is that this is a USB 1.1 to serial adapter and the USB connections on my new computer (a Thinkpad T42p, for those interested) are USB 2.0. Since I didn't discover the fact that Mike's recommended adapter was a USB 1.1-based adapter until after I hung up w/ him, I didn't get a chance to ask him about it on the phone Confused Technically, my 2.0-based USB connections should be able to handle 1.1-based peripherals, but theory and reality aren't always the same...
Anyhow, I'll be using the serial port to control Ashly digital units  via the Ashly Protea Control software as well as via Smaart. Naturally, I'd like to be able to interface with other RS-232-interface products as well Wink So, with that in mind, what are you using and how well is it working out?
I appreciate your thoughts/comments/suggestions! Cheers!
Charles Johnson
PS Mike - just for the record, I'm not faulting you at all for your recommendation! I was the one who goofed and didn't discover the 1.1 vs 2.0 protocol issue until it was too late.
Geri O'Neil
Re: USB to Serial Adapters
« Reply #1 on: December 03, 2004, 07:02:16 pm »
Hey, Charles. I gotta do this quick as I'm running out the door to a show, but I'm using a PC-Card-to-2-serial-port adapter cable. I went through 2 USB-to-serial units and didn't like either one of them. They worked irratically and they consisted of a box that you had to power up (with a wall-wart, naturally), connect to the notebook with a USB cable, then connect to the serial device with a third cable. What a trainwreck! This PC card thing goes, naturally, in the PC card slot of the notebook and breaks out into two serial cables. One set of cables coming from the computer. No power requirements. And the notebook sets up the two serial ports as extra COM ports. I'm controlling an EAW MX-8750 and a set of Ashly Protea EQs at the same time and never an issue to deal with. They also make a unit that breaks out into 4 serial ports. I didn't that many at the time, but the day ain't over... Very Happy
I'll e-mail you some more info when I get in tonight. Sorry, I didn't get the pics of the Protea remote cover you asked about, the thing went out yesterday with the respective rack and won't be in until Monday. YIKES!! GOTTA FLY LIKE THE ODIFEROUS STRIPED WIND THAT WE'RE FAMOUS FOR AROUND HERE!!
More later, Geri O
"Stagelite Sound...A Pin 2 hot-compliant company"
Sebastiaan Meijer
« Reply #2 on: December 03, 2004, 07:24:47 pm »
Charles,
Never had an USB 1.1-device fail on an USB 2.0 port. But hey, this is mission critical.
For my powerbook I recently acquired a Keyspan USB 28 adapter, a unit that exists for PC too. Works flawless. Before putting it at work I'm bench testing the alive time and such and it has been online via VirtualPC 7 to the Soundweb for more than 24 hours.
Now if MacFOH comes to the package Smile Wet dreams......
Sebas
Psycho-acoustic care-taker, but you may call me monitor dude.
EQ is like fast-food: quick, predictable and available everywhere, but it never tastes good if you need it.
Shanne Flemming
« Reply #3 on: December 03, 2004, 08:48:31 pm »
I use keyspan as well, never had a problem. If you have several USB ports, you will need to find the com port / USB port your hardware is looking for.
Shane
Juan Turro
« Reply #4 on: December 03, 2004, 10:43:05 pm »
I regularly use the IOgear adapter you mentioned without any trouble and have done so for a few years.  My current laptop has USB 2.0 ports and that does not present any problems.  I have used the IOGear with Soundweb among other audio units.  There was one unit I tried a while back that did not work but it was something I have not used again since so it was unimportant.  The IOgear is USB powered and not in a box.  It is very compact and the electronics are built into the DB-9 connector.  That is why I like it.  It is also sold by Aten who I believe is the manufacturer.  IOgear only resells it under their name.  I hear occasionally about some people who experience issues with USB/RS232 adapters with certain pieces of equipment. Usually it is an older piece of equipment or something not that mainstream.  The PCMCIA to serial port solutions Geri O mentions are usually more compatible with most devices in my experience.  I believe the reason is that the card holds actual UART serial hardware vs. the virtual serial port of the USB adapter.  I have an old IBM PCMCIA adapter I bought years ago that worked well on a lot of equipment.  I think the reason I don't use it much is that I don't like to leave the PCMCIA card in my laptop.  The cable was too long and harder to store in my ultra compact laptop bag.  I already need to take a null modem cable with me.  I also did not like the tiny connection the cable uses to connect to the PCMCIA card.  I realize there are not all the way.  The better PCMCIA/serial adapters I have seen are from Socket and there was one other I cannot recall at the moment, I think it may be Quatech.  There are some Socket units on Ebay at the moment.  I hope this makes sense as I too am in a hurry and wrote this up quickly.  I hope that helps.
Juan
Juan Turro
AVS Production Group
New York , NY
juan.t@avspg.com
Andy Peters
    • http://www.latke.net/
« Reply #5 on: December 04, 2004, 03:31:51 pm »
Charles Johnson wrote on Fri, 03 December 2004 12:32
Time to don the USB-guy hat:
USB 2.0 is backwards-compatible with USB 1.1.  The main difference between the two specs in terms of devices is that 2.0 supports high-speed transfers (480 Mbps), in addition to the two older speeds (full speed or 12 Mbps and low speed, 1.5 Mbps).  The serial gizmo you mention is a full-speed device (probably based on the ubiquitous FTDI chips) and your USB 2.0 host controller in your laptop should have no problems with it.  If there ARE problems, then the device is broken.
RS-232 ports present an interesting problem.  The transmit and receive lines are independent.  Some PC applications will do things like send a command and then expect some sort of response.  RS-232 will allow the response to be almost immediate, although the application may have a timeout, which means that if it doesn't get a response from the device in a certain amount of time, it aborts whatever it was doing and may even think that the device isn't connected.
USB, on the other hand, forces the commands and responses into "packets," and the packets are sent at regular intervals.  If that interval between responses is "too short," then you end up wasting bandwidth because the host (the PC) is always asking the device "do you have anything for me?" and most of the time the answer is no.  If the interval is "too long," then the application may time out because it didn't get a response in time.
Since USB 2.0 is the latest/greatest version of the spec, it's probably impossible to buy a new PC that has USB 1.1 ports.
Another point: you'll probably see lots of devices that are advertised as USB 2.0.  Don't assume that they are high-speed devices unless the packaging explicitly says so.
-a
"This isn't some upside down inverted Socratic method where you throw out your best guess answers and I correct your work." -- JR
Josh Evans
    • http://www.youtube.com/jevans111
« Reply #6 on: December 09, 2004, 09:20:05 am »
Why not just go wireless?
http://www.extron.com/product/product.asp?id=iplts2
http://www.lantronix.com/device-networking/external-device-s ervers/wibox
.html
http://www.lantronix.com/device-networking/external-device-s ervers/secur
ebox-sds1100.html
www.otcwireless.com
This was discussed on www.synaudcon.com list serve a couple of days ago.
Also iv used the cheap Radio Shack interface with some success.
cheers,
Joshua Evans
Outlinearrays.com
"Sound is what happens when air gets pushed"
Charles Johnson
« Reply #7 on: December 09, 2004, 11:41:14 pm »
Andy Peters wrote on Sat, 04 December 2004 15:31
They...recommended the GUC232A from IOGear.
Time to don the USB-guy hat...
Andy,
Since I may need more than 1 serial port at the same time, might something like this from Keyspan be a good idea? Or should I just buy a USB hub and multiple single-serial-port adapters like the IOGear unit?
FYI, it's looking like I'll be using the USBPre for Smaart, so that will take up 1 of my laptop's 2 USB ports. For some shows, the only other USB-based connection I'll need will be to tie in to my Yamaha 01V96. However, for other shows, I'll need at least 1 or more serial ports (to control digital EQs and system processors). For the latter shows, I may or may not be using my digital console, so I won't always need the digital console connection.
Thus, I'm thinking that perhaps the Keyspan device would cover my serial needs and when I need to connect to more than 2 USB devices, I'll use a small USB hub. How does that sound to you? What (if any) potential problems might I encounter with such a setup?
I greatly appreciate the info! Cheers!
Charles Johnson
Andy Peters
« Reply #8 on: December 10, 2004, 12:07:26 am »
Charles Johnson wrote on Thu, 09 December 2004 21:41
It's probably got a hub already built in.  I took a different one of those four-porters apart, and it had a hub chip and attached to the four downstream hub ports (inside, no external connections, it's all on the PCB) were four of the FTDI232 USB-to-RS232 chips.
When you first plug it in, it'll enumerate the hub, then it will enumerate each of the four USB-to-RS232 chips in turn.  It's stupid, because if you plug it into a different port on your computer it'll re-do the whole thing the first time.  Stupid Windows.
I would make sure to dedicate a port on the laptop for the USBPre and use another port for the serial thing or a hub.  You're also going to have a tangle of DC wires for all of those things!
-a
Charles Johnson
« Reply #9 on: December 10, 2004, 07:25:11 am »
Andy Peters wrote on Fri, 10 December 2004 00:07
Andy,
Actually, since both the USBPre and the Keyspan units are USB-powered, I won't have any wall-warts to deal with Very Happy (well, I'll have the line-lump for my laptop, but that's already a given)
Charles Johnson
Page created in 0.066 seconds with 21 queries.
