Author Topic: audio triggering  (Read 2373 times)
Mindwarper
audio triggering
« on: December 01, 2004, 07:29:10 pm »
 Hi All,
I'm not sure this is the right place, but some of you  might have an idea. I need to trigger the audio of a art exhibit when people either cross an electric eye or stand on a matt. The exhibit will be shown for a month, and the sound will drive the people working nearby nuts if it is left on the intire time. Any suggestions. We have a small budget, so ideas over 150$ are out of the question. Any ideas, suggestions, or links?
asus p4533c@2.53 / 4x512 1066 @533
80 gb OS Drive  / 240 gb raid0 / 250 gb Export Drive ( caddie)
dvd burner/ cd burner/ floppy
Aardvark 20/20  soundcard
Matrox Rt.X100
Ati Radeon 9800 pro
19" Nec Fe991sb crt
Antec case SX1040BII
Xp Pro
Jerry Nuckolls
    • http://www.acousticsinfo.com
Re: audio triggering
« Reply #1 on: December 02, 2004, 10:19:19 pm »
Use your ir to pulse an electronic drum brain.  Then, use the midi output of the drum brain to trigger a mute group on your soundboard that is plugged into the channel that your cd is operating.  Use another ir device at a location where people are exiting and have that trigger the mute back on.
You should be able to borrow a drum brain from anybody who plays an electronic kit, or check out ebay for an alesis dm4 (they should be pretty cheap these days.
Good luck.
Jerry Nuckolls
Jerry Nuckolls
Acoustics Engineer
Image Media Solutions
Page created in 0.057 seconds with 19 queries.
